I'm trying to test mali for fbdev on my board. I have few questions about this.
1) Can I say that gpu is ported well when I run and passed all integration test programs(i.e., mali_base_jd_test, mali_base_map_test_quick, mali_base_ump_test, mali_egl_integration_tests) of DDK package?
What this test have to shows on the screen?
All integration test programs except 'mali_egl_integration_tests' didn't print anytihng on the screen. Is it okay?
2) 'mali_egl_integration_tests' printed two color -upper half is red and lower half is green - and later, it printed full white screen.
Is this the right screen output?
3) I modified the value of 'end_buffer_count' from 3 to 1 in 'mali_egl_winsys_tests.c' to fix the test error.
Because my board only has single frame buffer - fb0. Can I say that I passed test well in my case?
4) I got only 18 fps result from 'mali_egl_integration_tests'. How can I enhance the performance?
Thank you.
Nari
For my own information, on which board are you do this test ?
"you must be a licensee" ? mcgeagh DDK sources are non-free ?
Hi ackmicro,
The Kernel side component of the Mali driver is under GPL and is freely available on our website.
The userspace side component - referred here as the DDK sources - is proprietary and not freely available.
Only licensees of our DDK have access to the source code, but we do publish prebuilt binaries on our website for public use.
I hope that clarified things for you.
Kind Regards,
Michael McGeagh
Thanks for your explainations !
during a second You have make me fear
Okay, I'll contact to my SoC vendor.
Thank you for your reply.
Regards,
Hi monaami,
It sounds like you have access to our DDK sources, which means you are most likely a licensee.
This means you are possibly entitled to ARM support. I would recommending contacting them in order to make use of this service we provide.
The questions for this website do not delve into our DDK driver sources and build procedure, so we would not be able to answer that here.
