GA fragment count / gpu settings
I'm using Graphics Analyzer 5.7.0 from ARM Mobile Studio Starter Edition 2020.3.
1. I tried to capture a trace with fragment count enabled. The frame has 2 render passes. I can see valid fragment count in pass #1, but all zeroes in pass #0.
    What do I miss here? I'm sure pass #0 did rendered something.
2. According to User Guide, cycles in Shader View is coming from Mali Offline Compiler for Mali-T880.  Is it possible to change to other GPU, say Mali-G78?
  • Hi sabre,
    I'll check with the engineering team for the fragment count behavior to see if we have any known issues here.
    The the offline compiler the current tool only supports Mali-T880; if you want other GPUs you'll need to use the standalone Mali Offline Compiler shipped in Mobile Studio. We're working on a new major version of the tool, and getting this fixed for that version is definitely on the todo list.
    Kind regards,
    Pete
  • A late follow up here - sorry it took some time to reply.
    The fragment count mode uses shader replacement to emit instrumentation to a color attachment. It will not work for render passes that have no color attachment (e.g. depth shadow maps), or for cases where shader replacement fails.
    We've fixed a number of issues with float attachments in Mobile Studio 2021.2, so please give it a go an let us know if that helps. If it doesn't please can you share your .mgd file so we can see the behavior which is causing the problem.
    Kind regards,
    Pete
