We are developing Augmented Reality applications using Godot engine and we have integrated ARCore. We can successfully deploy an application on Android, and on devices based on Mali GPU (G71 etc), the camera feed is black (not showing) on the device screen, but it is tracking the space. On Adreno-based chips works perfectly,
Anyone with an advice?
Hard to provide advice without knowing exactly what you are trying to do. Can you share a minimal reproducer?Cheers, Pete
Hi Peter,
Here are more information.
We are using godot engine with ARCore integrated. On the devices with Mali G7x GPU we are getting the error below when the API tries to capture camera texture.
Attached is also GLSL shader.
Hope I provided sufficient info to initiate an idea what might be the problem.
I appreciated your response,
Cheers,
Nikola
/* clang-format off */ [vertex] layout(location = 0) in highp vec4 vertex_attrib; /* clang-format on */ #if defined(USE_CUBEMAP) || defined(USE_PANORAMA) layout(location = 4) in vec3 cube_in; #else layout(location = 4) in vec2 uv_in; #endif layout(location = 5) in vec2 uv2_in; #if defined(USE_CUBEMAP) || defined(USE_PANORAMA) out vec3 cube_interp; #else out vec2 uv_interp; #endif out vec2 uv2_interp; // These definitions are here because the shader-wrapper builder does // not understand `#elif defined()` #ifdef USE_DISPLAY_TRANSFORM #endif #ifdef USE_COPY_SECTION uniform vec4 copy_section; #elif defined(USE_DISPLAY_TRANSFORM) uniform highp mat4 display_transform; #endif void main() { #if defined(USE_CUBEMAP) || defined(USE_PANORAMA) cube_interp = cube_in; #elif defined(USE_ASYM_PANO) uv_interp = vertex_attrib.xy; #else uv_interp = uv_in; #ifdef V_FLIP uv_interp.y = 1.0 - uv_interp.y; #endif #endif uv2_interp = uv2_in; gl_Position = vertex_attrib; #ifdef USE_COPY_SECTION uv_interp = copy_section.xy + uv_interp * copy_section.zw; gl_Position.xy = (copy_section.xy + (gl_Position.xy * 0.5 + 0.5) * copy_section.zw) * 2.0 - 1.0; #elif defined(USE_DISPLAY_TRANSFORM) uv_interp = (display_transform * vec4(uv_in, 1.0, 1.0)).xy; #endif } /* clang-format off */ [fragment] #ifdef USE_EXTERNAL_SAMPLER // Leave the ifdef so we have this define, for now the extension is loaded through custom defines // #extension GL_OES_EGL_image_external_essl3 : require #endif #define M_PI 3.14159265359 #if !defined(USE_GLES_OVER_GL) precision mediump float; #endif #if defined(USE_CUBEMAP) || defined(USE_PANORAMA) in vec3 cube_interp; #else in vec2 uv_interp; #endif #ifdef USE_ASYM_PANO uniform highp mat4 pano_transform; uniform highp vec4 asym_proj; #endif // These definitions are here because the shader-wrapper builder does // not understand `#elif defined()` #ifdef USE_TEXTURE3D #endif #ifdef USE_TEXTURE2DARRAY #endif #ifdef YCBCR_TO_SRGB #endif #ifdef USE_CUBEMAP uniform samplerCube source_cube; //texunit:0 #elif defined(USE_TEXTURE3D) uniform sampler3D source_3d; //texunit:0 #elif defined(USE_TEXTURE2DARRAY) uniform sampler2DArray source_2d_array; //texunit:0 #elif defined(USE_EXTERNAL_SAMPLER) uniform samplerExternalOES source; #else uniform sampler2D source; //texunit:0 #endif #ifdef SEP_CBCR_TEXTURE uniform sampler2D CbCr; //texunit:1 #endif /* clang-format on */ #ifdef USE_LOD uniform float mip_level; #endif #if defined(USE_TEXTURE3D) || defined(USE_TEXTURE2DARRAY) uniform float layer; #endif #ifdef USE_MULTIPLIER uniform float multiplier; #endif #if defined(USE_PANORAMA) || defined(USE_ASYM_PANO) uniform highp mat4 sky_transform; vec4 texturePanorama(vec3 normal, sampler2D pano) { vec2 st = vec2( atan(normal.x, normal.z), acos(normal.y)); if (st.x < 0.0) st.x += M_PI * 2.0; st /= vec2(M_PI * 2.0, M_PI); return textureLod(pano, st, 0.0); } #endif uniform vec2 pixel_size; in vec2 uv2_interp; #ifdef USE_BCS uniform vec3 bcs; #endif #ifdef USE_COLOR_CORRECTION uniform sampler2D color_correction; //texunit:1 #endif layout(location = 0) out vec4 frag_color; void main() { //vec4 color = color_interp; #ifdef USE_PANORAMA vec3 cube_normal = normalize(cube_interp); cube_normal.z = -cube_normal.z; cube_normal = mat3(sky_transform) * cube_normal; cube_normal.z = -cube_normal.z; vec4 color = texturePanorama(cube_normal, source); #elif defined(USE_ASYM_PANO) // When an asymmetrical projection matrix is used (applicable for stereoscopic rendering i.e. VR) we need to do this calculation per fragment to get a perspective correct result. // Asymmetrical projection means the center of projection is no longer in the center of the screen but shifted. // The Matrix[2][0] (= asym_proj.x) and Matrix[2][1] (= asym_proj.z) values are what provide the right shift in the image. vec3 cube_normal; cube_normal.z = -1.0; cube_normal.x = (cube_normal.z * (-uv_interp.x - asym_proj.x)) / asym_proj.y; cube_normal.y = (cube_normal.z * (-uv_interp.y - asym_proj.z)) / asym_proj.a; cube_normal = mat3(sky_transform) * mat3(pano_transform) * cube_normal; cube_normal.z = -cube_normal.z; vec4 color = texturePanorama(normalize(cube_normal.xyz), source); #elif defined(USE_CUBEMAP) vec4 color = texture(source_cube, normalize(cube_interp)); #elif defined(USE_TEXTURE3D) vec4 color = textureLod(source_3d, vec3(uv_interp, layer), 0.0); #elif defined(USE_TEXTURE2DARRAY) vec4 color = textureLod(source_2d_array, vec3(uv_interp, layer), 0.0); #elif defined(SEP_CBCR_TEXTURE) vec4 color; color.r = textureLod(source, uv_interp, 0.0).r; color.gb = textureLod(CbCr, uv_interp, 0.0).rg - vec2(0.5, 0.5); color.a = 1.0; #else #ifdef USE_LOD vec4 color = textureLod(source, uv_interp, mip_level); #else vec4 color = textureLod(source, uv_interp, 0.0); #endif #endif #ifdef LINEAR_TO_SRGB // regular Linear -> SRGB conversion vec3 a = vec3(0.055); color.rgb = mix((vec3(1.0) + a) * pow(color.rgb, vec3(1.0 / 2.4)) - a, 12.92 * color.rgb, lessThan(color.rgb, vec3(0.0031308))); #elif defined(YCBCR_TO_SRGB) // YCbCr -> SRGB conversion // Using BT.709 which is the standard for HDTV color.rgb = mat3( vec3(1.00000, 1.00000, 1.00000), vec3(0.00000, -0.18732, 1.85560), vec3(1.57481, -0.46813, 0.00000)) * color.rgb; #endif #ifdef SRGB_TO_LINEAR color.rgb = mix(pow((color.rgb + vec3(0.055)) * (1.0 / (1.0 + 0.055)), vec3(2.4)), color.rgb * (1.0 / 12.92), lessThan(color.rgb, vec3(0.04045))); #endif #ifdef DEBUG_GRADIENT color.rg = uv_interp; color.b = 0.0; #endif #ifdef DISABLE_ALPHA color.a = 1.0; #endif #ifdef GAUSSIAN_HORIZONTAL color *= 0.38774; color += texture(source, uv_interp + vec2(1.0, 0.0) * pixel_size) * 0.24477; color += texture(source, uv_interp + vec2(2.0, 0.0) * pixel_size) * 0.06136; color += texture(source, uv_interp + vec2(-1.0, 0.0) * pixel_size) * 0.24477; color += texture(source, uv_interp + vec2(-2.0, 0.0) * pixel_size) * 0.06136; #endif #ifdef GAUSSIAN_VERTICAL color *= 0.38774; color += texture(source, uv_interp + vec2(0.0, 1.0) * pixel_size) * 0.24477; color += texture(source, uv_interp + vec2(0.0, 2.0) * pixel_size) * 0.06136; color += texture(source, uv_interp + vec2(0.0, -1.0) * pixel_size) * 0.24477; color += texture(source, uv_interp + vec2(0.0, -2.0) * pixel_size) * 0.06136; #endif #ifdef USE_BCS color.rgb = mix(vec3(0.0), color.rgb, bcs.x); color.rgb = mix(vec3(0.5), color.rgb, bcs.y); color.rgb = mix(vec3(dot(vec3(1.0), color.rgb) * 0.33333), color.rgb, bcs.z); #endif #ifdef USE_COLOR_CORRECTION color.r = texture(color_correction, vec2(color.r, 0.0)).r; color.g = texture(color_correction, vec2(color.g, 0.0)).g; color.b = texture(color_correction, vec2(color.b, 0.0)).b; #endif #ifdef USE_MULTIPLIER color.rgb *= multiplier; #endif frag_color = color; }
The repo: github.com/.../gles3
The error is thrown by this line:
... because Mali doesn't support external samplers for textureLod() calls. I'm assuming you don't have mipmaps for the camera image, so you can just replace this with:
vec4 color = texture(source, uv_interp);
HTH, Pete
Thanks for your help Pete,
It worked.
Much appreciated!
Cheers
Any time, happy to help.Pete
