glMapBufferRange fails with Out of memory error (Mali-G71 MP20)
I am encountering an out of memory error when calling glMapBufferRange to read back the result of a compute shader. The application works perfectly fine on my Samsung A5, but fails on an S8 (Mali-G71 MP20). Profiling the application reveals nothing, the memory usage is constant and does not increase over time. Additionally, the crash happens anywhere from 5s to 2 minutes after launching the application. I really have no idea how to debug this further. It seems to be an out of memory error within the driver that isn't visible in the profiler??
I do believe I'm making the correct openGL calls:
ByteBuffer buffer = ((ByteBuffer)GLES31.glMapBufferRange(
GLES31.GL_SHADER_STORAGE_BUFFER,
0,
xres*4,
GLES31.GL_MAP_READ_BIT));
GLES31.glUnmapBuffer(GLES31.GL_SHADER_STORAGE_BUFFER);
