GLES3+ GL_DEPTH_COMPONENT16-32 on Nexus 10/Mali T604
So I'm trying to create a Multisampled depth texture and I'm seeing some oddities.
First off, this GLES2-like call works :
glTexImage2D( GL_TEXTURE_2D, 0, GL_DEPTH_COMPONENT, Width, Height, 0, GL_DEPTH_COMPONENT, GL_UNSIGNED_SHORT, NULL );
But then I can't use it for the multisampled texture :
glTexStorage2DMultisample( GL_TEXTURE_2D_MULTISAMPLE, 4, GL_DEPTH_COMPONENT, Width, Height, GL_TRUE );
It throws GL_INVALID_ENUM and reading the docs it can only be from texture target which is ok so the next wrong thing is GL_DEPTH_COMPONENT .
Then I tried creating GL_DEPTH_COMPONENT16,24 and 32 textures
glTexImage2D( GL_TEXTURE_2D, 0, GL_DEPTH_COMPONENT16, Width, Height, 0, GL_DEPTH_COMPONENT, GL_UNSIGNED_SHORT, NULL );
glTexImage2D( GL_TEXTURE_2D, 0, GL_DEPTH_COMPONENT24, Width, Height, 0, GL_DEPTH_COMPONENT, GL_UNSIGNED_INT, NULL );
glTexImage2D( GL_TEXTURE_2D, 0, GL_DEPTH_COMPONENT32F, Width, Height, 0, GL_DEPTH_COMPONENT, GL_FLOAT, NULL );
And while they all work I don't see my depth buffer based effects like depth of field so I can only assume the values are either not being saved (all 0s) or the format is wrong, like I would need an integer sampler. I am expecting in these scenarios to use a standard sampler2D and get a .r-only texture with values from 0..1 . I have the exact same issue with Qualcomm's Adreno 320, but I don't have it with Apple's A7 GPU or my AMD R9 280X.
Am I doing something wrong ?
