Using DS-5 Streamline in Samsung Galaxy S5 Phone [?]
I want to use DS5 in Samsung Galaxy S5 phone (SM-G900H) having a Mali T628 GPU. Should I follow the tutorial as in Nexus 10 from the link below and download Android 4.4.2 kernel or download a specific SM-G900H from opensource.samsung.com?
Using DS-5 Streamline with Mali on Google Nexus 10
Will either of those kernel build-ups work equally well? Moreover, in the tutorial using on Galaxy Note 3, ODIN is used to insert a custom kernel. Is that the case with Samsung Galaxy devices also? I was not able to access the bootloader using this command below:
adb reboot bootloader
Using ,the phone was just re-starting up and not going to bootloader. Is that the general case with S5 devices? Is there any work-around for inserting the new custom boot.img file?
