Rendering to RGBA4444, alpha channel weirdness?
I'm doing rendering of non-color data to an RGBA4444 texture, and I'm seeing some difference in how the output from the alpha channel gets stored in the texture. It seems somehow that the alpha channel gets it's range slightly compressed, leading to higher contrast for the contents.
This happens on a Samsung Galaxy S3, which has a Mali-400 GPU. On other GPUs, I don't see these issues. GL_DITHER is disabled.
OpenGL ES 2.0 defines the same transformation from floating-point to the framebuffer's fixed-point representation for RGB and A in this case, so AFAICT there shouldn't be any difference.
Why does this happen? Am I misunderstanding the spec? If not, is there something I can do to work around the issue?
0
