Dear All,
I want to say really thanks for everyone. Because when I have a question, always this forum give me a precious answer
Cut to the chase, I am wondering whether I can measure the power performance of Mali GPU based on Samsung Chromebook 2.
Or any technical document about power performance when I use just one Mali GPU compute unit.
Thanks a lot, in advance
Yours sincerely,
Woojung Myung
oh sorry, the other one..
and I am doing OpenCL programming to analyze performance of GPU computation..
but is there any solution to vary the number of GPU compute unit?
Actually, I can use 2 compute and 4 compute units on SS chromebook 2,
(when I used 2 compute units and 4compute units to check the time performance, the results are not very big different. I guess it will show me 2 times time performance difference)
So I tried to make work group to compute each of work group on individual compute unit,, when I used 2 or 4 compute unit GPU device respectivley,
but when I see the time performance, also the results are almost same..
Thanks..
Hi nightskyz,
Unfortunately production devices such as the Samsung Chromebook 2 it is not possible to get power measurements without hardware modifications. The Odroid X-U3, however, is exactly the same SoC, Exynos 5422, as the Samsung Chromebook 2 but already has the hardware modification for power measurement when you buy it. If you are interested in power measurement, I can recommend the Odroid X-U3.
As for OpenCL on the Chromebook 2, whilst there are 6 Mali cores in the device, they are arranged into two logical core groups with 2 and 4 Mali cores respectively, that appear as two different OpenCL devices. As such it is only possible to run your kernel on either the 2 or the 4, not all 6 (unless you create two contexts, one for each device and execute your kernel on both devices simultaneously).
With regards to the performance difference between the core group with 2 or 4 cores, without knowing what code you are running I can't really speculate as to why you wouldn't see a 2x performance with 2x cores. Could I recommend taking a read of the Mali OpenCL optimization guide for T600 series: http://infocenter.arm.com/help/topic/com.arm.doc.dui0538f/DUI0538F_mali_t600_opencl_dg.pdf. That may give you some useful information on how compute programs can be written in such a way as to scale better on Mali GPUs.
Hope this helps,
Rich
Thanks richevans
By the way.. then which means even there's no way to guess the power performance of GPU core unit based on SS chromebook 2?
now I know X-U3 can be a good alternative, but the problem is I do not have enough time to buy and do the same job on X-U3..
Because of my project deadline.. I really need the power consumption data of one compute unit..
Is there any other way to know power data based on frequency? Or Vdd and I? I thought probably ARM has kind of datasheet of Mali GPU...
I already googled it, but unfortunately I couldn't fine it..
Thanks a lot,
Unfortunately there is no way to get these power numbers without an instrumented device which the retail Chromebook 2 isn't.
The power consumption of the core depends on a huge number of variables, the SoC and its process, kernel configuration, workload, environmental factors, the nature of the work being done and as such we can't provide any estimates, even for where things like frequency are known. You can of course calculate the power consumption if Vdd and I are known for the core, but there is no way for you to obtain this information from the device without making hardware modifications.
My only suggestion is, unfortunately, to get yourself an Odroid X-U3 which is already instrumented and will allow you to take power measurements yourself.
I'm sorry I can't be of more help in this case,
Hey!
Is there any information as to why the 6 cores are divided into two logical cores?
(I'm sory for re-opening a closed topic, if you prefer i can open a new one?)
Thanks anyway!
Rui
Hi Rui,
T6xx GPUs implement cores in core "groups" with a maximum of 4 cores in any given group. This is abstracted away for GLES, but for CL this is exposed as 2 separate CL devices to applications.
Hth,
Chris
