Instanced Rendering in OpenGL es 3.0
i was trying to develop a test case for instanced rendering. I am trying to render multiple cubes using glDrawArraysInstanced() as well as glDrawArrays().
but the offset values passed in glDrawArraysInstanced()  do not give required output as obtained incase of rendering with  glDrawArrays().
here is the code snippet as well as the shader code used.
if(!INSTANCE_RENDERING)
                for(int j=0;j<INSTANCE;j++)
                    glUniform3f(offLocation,  offset[n], offset[n+1], offset[n+2]);
                    Matrix modelView = Matrix::createRotationXYZ(angle+i, angle+i, angle+i);
                    glUniformMatrix4fv(matrixLocation, 1, GL_FALSE, modelView.getAsArray());
                    glDrawElements(GL_TRIANGLES, 36, GL_UNSIGNED_SHORT, (void*)0);
                    if(offset[n] > th || offset[n+0] < -1*th) {dir[n+0] = -1* dir[n+0]; }
                    if(offset[n+1] > th || offset[n+1] < -1*th) {dir[n+1] = -1 *dir[n+1];}
                    offset[n] += dir[n];
                    offset[n+1] += dir[n+1];
                    offset[n+2] += dir[n+2];
                    n +=3;
            //glClearColor(0.0f, 0.0f, 0.0f, 1.0f);
        else //instance rendering enabled
                    glDrawElementsInstanced ( GL_TRIANGLES, 36, GL_UNSIGNED_SHORT, ( const void * )0, INSTANCE );
                    n +=3;
shader source code
  // Fragment and vertex shaders code
       std::string str = " precision mediump float;\
       varying vec4 vColor;\
       void main(void) {\
        gl_FragColor = vColor;\
    const char *pszFragShader = str.c_str();
    std::string str2 = "precision highp float;\
         attribute vec3 aVertexPosition;\
    attribute vec4 aVertexColor;\
    uniform mat4 uMVMatrix;\
    uniform mat4 uPMatrix;\
    uniform vec3 aOffsetPosition;\
    vec4 position;\
    void main(void) {\
        position = vec4(aVertexPosition, 1.0)+ vec4(aOffsetPosition, 45.0) ; \
        gl_Position = uPMatrix * position;\
        vColor = aVertexColor;\
0
