Mali hardware acceleration on Samsung Chromebook 2
Is there a guide anywhere on getting hardware acceleration working properly on the Samsung Chromebook 2 or the Hardkernel ODroid XU3?  These devices use the Mali T628.  I have followed the guide at Graphics and Compute Development on Samsung Chromebook - Mali Developer Center Mali Developer Center , however the performance is lackluster.  My suspicion is with the armsoc DDX driver.  I believe that the guide was written with regards to the older Samsung Chromebook that used the Mali 400.
es2info shows that the system is not using mesa software rendering.  I obtain about 200fps with es2gears, and when the window is enlarged, the framerate drops to about 30fps.  The biggest problem is with 2D performance.  I realize that the Mali devices are not 2D, but that the driver should be passing on the 2D operations to 3D via Glamor or the like.  Moving windows such as a web browser around on the desktop results in very poor performance and user interface latency.
Is there a different xf86 driver that should be used with the T628?
