I am working on GLES program using ARM GLES3.0 Emulator ver 1.4. I could figure out that
1. glMapBufferOES fails with GL_ELEMENT_ARRAY_BUFFER as target parameter.(ref: http://community.arm.com/thread/6189)
2. Limitation section of User Guide for ARM GLES3.0 Emulator ver 1.4 says glShaderBinary/glProgramBinary fails.
Can I expect these fixes in coming release? If yes, when should I expect next release?
Cheers,
Sunil
Hi Sunil,
For 1. the issue is that the mapbuffer OES spec is written such that it inherits its behaviour from the OpenGL 2.0 spec, which did not include GL_ELEMENT_ARRAY_BUFFER as a valid target. I have mentioned it to the team that it would be nice to support this.
For 2., there is a fundamental issue of binary incompatibility; the mali binaries will not run on anything other than the Mali GPU and driver pairing which they were compiled for. The simple workaround here is to just work with shader source in the emulator, and only use program binaries on target devices. I don't believe there are any plans to support Shader/Program binaries at this time.
Hth,
Chris
