Summary
Is OpenCL support for the Mali-T628 (for example as found in the Exynos 5420 SoC on the Arndale Octa board) available? If so, how to set it up?
More details
According to the vendor, OpenCL should be supported, but the Arndale Octa Wiki does not state how this can be achieved.
I am using the latest Linaro developer build and installed Mali drivers that contain OpenCL libraries for Mali T604. According to this guide, the driver actually contains references to the Mali T628. So I tried to create the udev rule as specified, which is supposed to solve a permission problem with /dev/mali0, but I found that there is no /dev/mali0 on my installation at all. So my conclusion is that the driver indeed does not support T628.
When I execute a clinfo utility, clGetDeviceInfo returns CL_OUT_OF_HOST_MEMORY for some device properties. Why can I query the GPU for some characteristics, but does this fail for some others? When running a normal application, the same error appears when trying to create an OpenCL Context.
I was surprised to find this topic, where yoshi seems to have OpenCL working and can run benchmarks on his Arndale Octa board. How is this possible if there is no driver available? Or am I just missing something? I hope that you can help me to also establish a working OpenCL development environment.
Hi Rich,
Good to know the difference between X11 and fbdev. I have one follow-up question on this. So far I have linked my OpenCL programs to libmali.so from the userspace binary package instead of using the libOpenCL.so, since libOpenCL.so gives me lots of undefined reference errors whilst using libmali.so, compilation progresses without any errors. I also noticed that libmali.so is the only substantial file in the package:
# ll ../fbdev/ total 21056 drwxr-xr-x 2 root root 4096 Jan 1 2000 ./ drwx------ 11 root root 4096 Jan 1 2000 ../ -rwxr-x--- 1 16580 16580 4806 Jul 23 14:44 libEGL.so* -rwxr-x--- 1 16580 16580 4806 Jul 23 14:44 libGLESv1_CM.so* -rwxr-x--- 1 16580 16580 4806 Jul 23 14:44 libGLESv2.so* -rwxr-x--- 1 16580 16580 4806 Jul 23 14:44 libOpenCL.so* -rwxr-x--- 1 16580 16580 21518354 Jul 23 14:44 libmali.so*
# ll ../fbdev/
total 21056
Is using libmali.so to lik against the correct way to go?
Regarding DVFS, the /device/dvfs file is not present on my system:
# tree /sys/class/misc/mali0 /sys/class/misc/mali0 ├── dev ├── device -> ../../../11800000.mali ├── power │ ├── autosuspend_delay_ms │ ├── control │ ├── runtime_active_time │ ├── runtime_status │ └── runtime_suspended_time ├── subsystem -> ../../../../class/misc └── uevent 3 directories, 7 files
├── dev
├── power
│ ├── control
└── uevent
And your command results in a permission denied error, even though I am using a root shell:
# echo off > /sys/class/misc/mali0/device/dvfs -bash: /sys/class/misc/mali0/device/dvfs: Permission denied
I am looking forward to seeing your clpeak results!
Hi bramv,
"libOpenCL.so" is the spec defined library name that OpenCL should be exposed as on the platform. In our case we implement this (and the GLES libs) as shims which pass through to the libmali.so binary, which is why that's the largest one there. For development purposes you can link against either, but obviously you wouldn't want to do this for a release, you'd want to link against libOpenCL.so for portability.
That said, it SHOULD work, so if you are having issues linking against libOpenCL.so feel free to share them here and we will take a look. I can't think of a good reason why one should work and the other fail.
Thanks,
Chris
All the errors are undefined reference errors at link time, the symbols should be there so offhand not sure why that's happening, but in any case linking against libmali.so is working
In your above output, ldd a.out is reporting /usr/lib/libmali.so on the first line, so thats working as expected.
Hth,
Hi Chris,
I put all files from the binary userspace driver in the /usr/lib/ directory and compiled just using: "g++ program.cpp -lOpenCL". This gives the same result as compiling like this: "g++ program.cpp /usr/lib/libOpenCL.so". The output is too long to show here.
Compiling using "g++ clpeak-arndale-octa.cpp /usr/lib/libmali.so" works just fine: But now that I am further looking into the compilation, I noticed the following:
# ldd a.out /usr/lib/libmali.so (0xb5e03000) libstdc++.so.6 => /usr/lib/arm-linux-gnueabihf/libstdc++.so.6 (0xb5d4a000) libm.so.6 => /lib/arm-linux-gnueabihf/libm.so.6 (0xb5cde000) libgcc_s.so.1 => /lib/arm-linux-gnueabihf/libgcc_s.so.1 (0xb5cbd000) libc.so.6 => /lib/arm-linux-gnueabihf/libc.so.6 (0xb5bd6000) /lib/ld-linux-armhf.so.3 (0xb6f6d000) librt.so.1 => /lib/arm-linux-gnueabihf/librt.so.1 (0xb5bc8000) libpthread.so.0 => /lib/arm-linux-gnueabihf/libpthread.so.0 (0xb5bac000) libdl.so.2 => /lib/arm-linux-gnueabihf/libdl.so.2 (0xb5ba1000)
# ldd a.out
The resulting binary does not contain any reference to a OpenCL or Mali library. Does this mean that the program runs on the CPU instead of GPU? But then, why does it report the two Mali-T628 devices? I am confused.
Whoops, I missed that line. In that case I can conclude the following:
I am running a kernel containing the proper Mali kernel driver, my program is linked to the corresponding userspace binary and T628-MP6 is correctly recognized.
Is it indeed DVFS that is preventing the benchmark to achieve the expected performance level? Why is /sys/class/misc/mali0/device/dvfs missing?
Hi Bramv,
Taken shamelessly from an answer by peterharris in another thread:
"The DVFS code for the GPU is not directly managed by our drivers - it is part of the platform integration provided in the BSP from Insignal. This style of integration occurs because the DVFS analogue parts which control F and V for the power domains are not part of the ARM IP. This question is probably best asked to Samsung or Insignal, as they maintain the BSP for that platform."
It is possible to disable features such as DVFS by recompiling the linux kernel and mali kernel module with the correct configuration. The reason this reduced performance (normally) happens is because DVFS ties the GPU frequencies to the workload of the CPU. As you are running your intensive GPU test, the CPU is left to idle and so DVFS drops the CPU core speed, unfortunately, also dropping the GPU frequency.
A means of stopping this happening would be to add some CPU intensive code to run whilst the GPU code is running to stop DVFS dropping the frequencies.
Hope this Helps,
Rich
With regards to the Linker errors, you should be able to fix the issue by linking against both mali and OpenCL. OpenCL will provide the runtime linker target (even in the absence of mali) whilst mali will provide the symbols at compile time, stopping the errors in your shared paste.
Hope this helps,
I just tried to run the GPU benchmark while the CPU was busy compiling a new kernel. There are however no significant differences in the results.
To see whether I could make DVFS work, I enabled "CONFIG_MALI_MIDGARD_DVFS=y", but this results in undefined references while compiling:
LD init/built-in.o drivers/built-in.o: In function `mali_dvfs_update_asv': :(.text+0x517a8): undefined reference to `exynos_lot_id' :(.text+0x517ac): undefined reference to `exynos_lot_id' drivers/built-in.o: In function `mali_sysfs_show_asv': :(.text+0x51ab6): undefined reference to `exynos_asv_group_get' :(.text+0x51b2a): undefined reference to `exynos5420_is_g3d_mp6' :(.text+0x51b50): undefined reference to `exynos_lot_id' :(.text+0x51b58): undefined reference to `exynos_lot_id' drivers/built-in.o: In function `mali_dvfs_event_proc': :(.text+0x51fc8): undefined reference to `exynos_result_of_asv' :(.text+0x51fcc): undefined reference to `exynos_result_of_asv' make: *** [vmlinux] Error 1
LD init/built-in.o
Are you using the same kernel configuration that Guillaume mentioned?
./scripts/kconfig/merge_config.sh linaro/configs/linaro-base.conf linaro/configs/distribution.conf linaro/configs/arndale_octa.conf linaro/configs/lt-arndale_octa.conf linaro/configs/mali-arndale-octa.conf
I've not been able to look into this a huge amount for you unfortunately.
I was able to compile your code and run it on an Odroid X-U3 which is running a very similar SoC and I didn't see performance numbers anywhere near what you see, they are somewhat better. I can only assume this is a BSP issue, but I haven't had an Arndale Octa at hand to create my own BSP and test.
I will try and investigate at this end when I get the opportunity ,
I really appreciate the efforts that you (and all others in this topic) put into helping me, so don't worry!
It is good to hear that you have been able to compile and run my code. Could you elaborate on the performance numbers that the program outputs? Are they anywhere near the numbers?
Bram
It has been some time ago since the last post. Does anyone of you have any update on this?
Rich has been assigned onto other projects currently so will not be able to look into this for a while.
I will see if we can pick this up, but there may be a delay. I apologise for this.
Kind Regards,
Michael McGeagh
