I'm using Mali 400mp for doing some mathmetic computing.But the result is not satisfying.
In my program, I put a float array A by using gluniforlfv() into the shader,and put a Image Texture B by using glTexImage2D() into the shader,use the values in A and values in B to do mathmatic computing.
I use Mali's parameter to se OpenGL ES2.0 environment:
protected int redSize = 8;
protected int greenSize = 8;
protected int blueSize = 8;
protected int alphaSize = 8;
protected int depthSize = 16;
protected int sampleSize = 4;
protected int stencilSize = 0;
The txture parameter is:
glTexImage2D(GL_TEXTURE_2D, 0, GL_RGBA, texwidth, texheight, 0, GL_RGBA, GL_UNSIGNED_BYTE, Data);
The problem is :
Firstly, when I use gluniformlfv() to put a float array into the shader, the value in shader for computing is not the same as its real value.For example, if the value is 0.123456, however, in shader, the value is bigger or smaller in fact .So as other values.
Secondly, When I doing some computing in shader, it seems the result is not right for addition ,division etc. The result has some difference with the idealized mathmatic computing. I don't know why.
Hi Autman,
Are these calculations you are doing in a fragment shader? If so you will need to bear in mind that the floating precision required by OpenGL ES fragment shaders is FP16. This gives you roughly three decimal places of precision, so it may explain why you are not seeing as high a level of precision as the values you are putting into your float array. The Mail400 GPU supports 16-bit float arithmetic in the fragment shaders - as required by the spec - and up to 24-bit float for texture lookups using values passed through unaltered from the vertex shader stage.
Hope that helps,
Tim
http://www.khronos.org/registry/gles/specs/3.0/GLSL_ES_Specification_3.00.4.pdf section 4.5 here details the requirements for different precision levels in GLSL ES, expecting any more is outside of the spec and is not guaranteed to work on every conformant implementation. There might also be some information in the GL ES spec itself.
Hope this helps,
Chris
Hi Tim,
Thank you for your reply.I do these calculations in the fragment shader.Your reply is very useful.Your last sentense means that if I give the float array to vertex shader and then pass to fragment shader the result will be better,isn't it? And how about the result of the calculation in fragment shaders, for some calculations the difference is at the first decimal.For example, if the result should be 128.3567,the fragment shader is 128.2436,however.
Thank you.
Best wishes.
Autman
Floats passed from vertex to fragment shader will keep 24 bits of precision as long as you don't do any further calculations on them using them only for a lookup into a texture. As soon as you do any calculation on them within the fragment shader the precision will drop to FP16.
This would be expected. An FP16 value can represent a value of approximately 3 decimal places... so in this case these three are taken up by "128". If you could normalise all the values so the maximum value was 1 then you could count on the three places to the right of the decimal point being more or less accurate.
I hope that helps,
