While working with gnome-shell (X11, cogl & mutter doing window compositing) we see a strange issue when eglCreateImageKHR() is used to get an OpenGLESv2 texture of an X11 window pixmap.
We are working with Mali-400 driver r3p2-01rel0 on Exynos4412, running gnome-shell under Linux/X11.
base: BUILD=RELEASE ARCH=arch_011_udd PLATFORM=default_7a TRACE=0 THREAD= GEOM= CORES=MALI400 USING_MALI400=1 TARGET_CORE_REVISION=0x0101 TOPLEVEL_REPO_URL=Linux-r3p2-01rel0 REVISION=Linux-r3p2-01rel0 CHANGED_REVISION=Linux-r3p2-01rel0 REPO_URL=Linux-r3p2-01rel0 BUILD_DATE=Fri Jan 11 14:58:31 UTC 2013 CHANGE_DATE=Linux-r3p2-01rel0 TARGET_TOOLCHAIN=gcc HOST_TOOLCHAIN=gcc TARGET_TOOLCHAIN_VERSION=gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) HOST_TOOLCHAIN_VERSION=gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) TARGET_SYSTEM=gcc-arm-linux-gnueabihf HOST_SYSTEM=gcc-arm-linux-gnueabihf CPPFLAGS= CUSTOMER=internal VARIANT=mali400-r3p2-gles11-gles20-linux-ump-x11 HOSTLIB=direct INSTRUMENTED=FALSE USING_MRI=FALSE MALI_TEST_API= UDD_OS=linux
For windows that XGetGeometry reports as 32-bit color depth (i.e. some transparent regions), Mali's EGL returns a well-behaving texture. However, for windows that are 24-bit color depth (i.e. no transparency), we get strange behaviour. It is hard to classify exactly what is 'odd' with the resultant textures, but it is as if they have a bad alpha channel. We'd expect all alpha values to be 1 (opaque) but when blending with other textures under certain situations, the window textures act as if they have corrupt alpha values, so we see some of the desktop poking through in "random" pixels of the window.
1. Can a mali dev explain how eglCreateImageKHR() is implemented internally? How does it locate pixmap data and create a texture from it? I figure that it must interact with X somehow here, and as X is open source, maybe we can hack something in on the X side which sanitizes the alpha channel before Mali picks it up. (OTOH, we don't have Mali DDK to be able to attempt some fix on the Mali side...)
2. Would it be possible to get this fixed in Mali? Even if that happens I'm interested in the above explanation, because it seems unlikely we'd get a new libMali from someone with the DDK for some time...
For eglCreateImageKHR(..EGL_NATIVE_PIXMAP_KHR..), the driver will use XGetGeometry to get the depth, and DRI2GetBuffers to get the width, height and other info from pixmap.
Can you share your sample code with us for further debugging?
Thanks,
Frank
Hi dsd,
Did Frank's reply solve the issue for you or do you need more information. If the latter would you be able to supply some sample code as Frank suggests?
Thanks for the info. I was curious where it gets the actual pixel data, but I think your response indicates that: it receives the UMP ID from DRI2GetBuffers (via the returned DRI2 buffer name), and can then use UMP to retrieve the pixel data.
I will see if I can find some time to come up with a simple test case. It is one of those problems that is hard to put a finger on exactly which conditions cause it.
I think this may just be a bug with the xf86-video-fbturbo DDX. As Frank points out, it is the DDX that is responsible for inputting the window contents into the GL system, and this issue has gone away now that we have moved to xf86-video-armsoc. So you can consider this as a bug outside of the reach of this forum, and not in ARM code (I think). Thanks.
Thanks for feeding this back dsd!
Chris
May I ask for help on (example source code / documentation) on how to create an EGLImage usiing eglCreateImageKHR on X11?
I am currently using odroid-xu3 running Ubuntu 15.04.
