public class VideoSurfaceView extends GLSurfaceView { VideoRender mRenderer; private MediaPlayer mMediaPlayer = null; public VideoSurfaceView(Context context, MediaPlayer mp) { super(context); setEGLContextClientVersion(2); mMediaPlayer = mp; mRenderer = new VideoRender(context); setRenderer(mRenderer); mRenderer.setMediaPlayer(mMediaPlayer); } @Override public void onResume() { queueEvent(new Runnable(){ public void run() { mRenderer.setMediaPlayer(mMediaPlayer); }}); super.onResume(); } private static class VideoRender implements GLSurfaceView.Renderer, SurfaceTexture.OnFrameAvailableListener { private static String TAG = "VideoRender"; private static final int FLOAT_SIZE_BYTES = 4; private static final int TRIANGLE_VERTICES_DATA_STRIDE_BYTES = 5 * FLOAT_SIZE_BYTES; private static final int TRIANGLE_VERTICES_DATA_POS_OFFSET = 0; private static final int TRIANGLE_VERTICES_DATA_UV_OFFSET = 3; private final float[] mTriangleVerticesData = { // X, Y, Z, U, V -1.0f, -1.0f, 0, 0.f, 0.f, 1.0f, -1.0f, 0, 1.f, 0.f, -1.0f, 1.0f, 0, 0.f, 1.f, 1.0f, 1.0f, 0, 1.f, 1.f, }; private FloatBuffer mTriangleVertices; private final String mVertexShader = "uniform mat4 uMVPMatrix;\n" + "uniform mat4 uSTMatrix;\n" + "attribute vec4 aPosition;\n" + "attribute vec4 aTextureCoord;\n" + "varying vec2 vTextureCoord;\n" + "void main() {\n" + " gl_Position = uMVPMatrix * aPosition;\n" + " vTextureCoord = (uSTMatrix * aTextureCoord).xy;\n" + "}\n"; private final String mFragmentShader = "#extension GL_OES_EGL_image_external : require\n" + "precision mediump float;\n" + "varying vec2 vTextureCoord;\n" + "uniform samplerExternalOES sTexture;\n" + "void main() {\n" + " gl_FragColor = texture2D(sTexture, vTextureCoord);\n" + "}\n"; private float[] mMVPMatrix = new float[16]; private float[] mSTMatrix = new float[16]; private int mProgram; private int mTextureID; private int muMVPMatrixHandle; private int muSTMatrixHandle; private int maPositionHandle; private int maTextureHandle; private SurfaceTexture mSurface; private boolean updateSurface = false; private static int GL_TEXTURE_EXTERNAL_OES = 0x8D65; private MediaPlayer mMediaPlayer; public VideoRender(Context context) { mTriangleVertices = ByteBuffer.allocateDirect( mTriangleVerticesData.length * FLOAT_SIZE_BYTES) .order(ByteOrder.nativeOrder()).asFloatBuffer(); mTriangleVertices.put(mTriangleVerticesData).position(0); Matrix.setIdentityM(mSTMatrix, 0); } public void setMediaPlayer(MediaPlayer player) { mMediaPlayer = player; } public void onDrawFrame(GL10 glUnused) { synchronized(this) { if (updateSurface) { mSurface.updateTexImage(); mSurface.getTransformMatrix(mSTMatrix); updateSurface = false; } } GLES20.glClearColor(0.0f, 1.0f, 0.0f, 1.0f); GLES20.glClear( GLES20.GL_DEPTH_BUFFER_BIT | GLES20.GL_COLOR_BUFFER_BIT); GLES20.glUseProgram(mProgram); checkGlError("glUseProgram"); GLES20.glActiveTexture(GLES20.GL_TEXTURE0); GLES20.glBindTexture(GL_TEXTURE_EXTERNAL_OES, mTextureID); mTriangleVertices.position(TRIANGLE_VERTICES_DATA_POS_OFFSET); GLES20.glVertexAttribPointer(maPositionHandle, 3, GLES20.GL_FLOAT, false, TRIANGLE_VERTICES_DATA_STRIDE_BYTES, mTriangleVertices); checkGlError("glVertexAttribPointer maPosition"); GLES20.glEnableVertexAttribArray(maPositionHandle); checkGlError("glEnableVertexAttribArray maPositionHandle"); mTriangleVertices.position(TRIANGLE_VERTICES_DATA_UV_OFFSET); GLES20.glVertexAttribPointer(maTextureHandle, 3, GLES20.GL_FLOAT, false, TRIANGLE_VERTICES_DATA_STRIDE_BYTES, mTriangleVertices); checkGlError("glVertexAttribPointer maTextureHandle"); GLES20.glEnableVertexAttribArray(maTextureHandle); checkGlError("glEnableVertexAttribArray maTextureHandle"); Matrix.setIdentityM(mMVPMatrix, 0); GLES20.glUniformMatrix4fv(muMVPMatrixHandle, 1, false, mMVPMatrix, 0); GLES20.glUniformMatrix4fv(muSTMatrixHandle, 1, false, mSTMatrix, 0); GLES20.glDrawArrays(GLES20.GL_TRIANGLE_STRIP, 0, 4); checkGlError("glDrawArrays"); GLES20.glFinish(); } public void onSurfaceChanged(GL10 glUnused, int width, int height) { } public void onSurfaceCreated(GL10 glUnused, EGLConfig config) { mProgram = createProgram(mVertexShader, mFragmentShader); if (mProgram == 0) { return; } maPositionHandle = GLES20.glGetAttribLocation(mProgram, "aPosition"); checkGlError("glGetAttribLocation aPosition"); if (maPositionHandle == -1) { throw new RuntimeException("Could not get attrib location for aPosition"); } maTextureHandle = GLES20.glGetAttribLocation(mProgram, "aTextureCoord"); checkGlError("glGetAttribLocation aTextureCoord"); if (maTextureHandle == -1) { throw new RuntimeException("Could not get attrib location for aTextureCoord"); } muMVPMatrixHandle = GLES20.glGetUniformLocation(mProgram, "uMVPMatrix"); checkGlError("glGetUniformLocation uMVPMatrix"); if (muMVPMatrixHandle == -1) { throw new RuntimeException("Could not get attrib location for uMVPMatrix"); } muSTMatrixHandle = GLES20.glGetUniformLocation(mProgram, "uSTMatrix"); checkGlError("glGetUniformLocation uSTMatrix"); if (muSTMatrixHandle == -1) { throw new RuntimeException("Could not get attrib location for uSTMatrix"); } int[] textures = new int[1]; GLES20.glGenTextures(1, textures, 0); mTextureID = textures[0]; GLES20.glBindTexture(GL_TEXTURE_EXTERNAL_OES, mTextureID); checkGlError("glBindTexture mTextureID"); GLES20.glTexParameterf(GL_TEXTURE_EXTERNAL_OES, GLES20.GL_TEXTURE_MIN_FILTER, GLES20.GL_NEAREST); GLES20.glTexParameterf(GL_TEXTURE_EXTERNAL_OES, GLES20.GL_TEXTURE_MAG_FILTER, GLES20.GL_LINEAR); /* * Create the SurfaceTexture that will feed this textureID, * and pass it to the MediaPlayer */ mSurface = new SurfaceTexture(mTextureID); mSurface.setOnFrameAvailableListener(this); Surface surface = new Surface(mSurface); mMediaPlayer.setSurface(surface); surface.release(); try { mMediaPlayer.prepare(); } catch (IOException t) { Log.e(TAG, "media player prepare failed"); } synchronized(this) { updateSurface = false; } mMediaPlayer.start(); } synchronized public void onFrameAvailable(SurfaceTexture surface) { updateSurface = true; } private int loadShader(int shaderType, String source) { int shader = GLES20.glCreateShader(shaderType); if (shader != 0) { GLES20.glShaderSource(shader, source); GLES20.glCompileShader(shader); int[] compiled = new int[1]; GLES20.glGetShaderiv(shader, GLES20.GL_COMPILE_STATUS, compiled, 0); if (compiled[0] == 0) { Log.e(TAG, "Could not compile shader " + shaderType + ":"); Log.e(TAG, GLES20.glGetShaderInfoLog(shader)); GLES20.glDeleteShader(shader); shader = 0; } } return shader; } private int createProgram(String vertexSource, String fragmentSource) { int vertexShader = loadShader(GLES20.GL_VERTEX_SHADER, vertexSource); if (vertexShader == 0) { return 0; } int pixelShader = loadShader(GLES20.GL_FRAGMENT_SHADER, fragmentSource); if (pixelShader == 0) { return 0; } int program = GLES20.glCreateProgram(); if (program != 0) { GLES20.glAttachShader(program, vertexShader); checkGlError("glAttachShader"); GLES20.glAttachShader(program, pixelShader); checkGlError("glAttachShader"); GLES20.glLinkProgram(program); int[] linkStatus = new int[1]; GLES20.glGetProgramiv(program, GLES20.GL_LINK_STATUS, linkStatus, 0); if (linkStatus[0] != GLES20.GL_TRUE) { Log.e(TAG, "Could not link program: "); Log.e(TAG, GLES20.glGetProgramInfoLog(program)); GLES20.glDeleteProgram(program); program = 0; } } return program; } private void checkGlError(String op) { int error; while ((error = GLES20.glGetError()) != GLES20.GL_NO_ERROR) { Log.e(TAG, op + ": glError " + error); throw new RuntimeException(op + ": glError " + error); } } } // End of class VideoRender.} // End of class VideoSurfaceView.[size=2]
I could confirm the error reported by Marco with two devices:- Gadmei E8-3D (Android 4.0.4)- M3 Enjoy TV Box (Android 4.0.4)
[/size] GLES20.glDisable(GLES20.GL_CULL_FACE); GLES20.glFrontFace(GLES20.GL_CCW);
Hi Everybody,
I'm reviving this post, as this problem is still out there and I still have no solution for it.
I've Mali -T764 based android 4.4.2 from OpenHour called Chameleon. It's fast and works well but they still have the same problem we discussed here.
The video runs in the background, and it's NOT copied to the surface (I can see it by changing my shader to add transparency)
The problem is what Pete says: "Mali supports it, but it must be correctly integrated into the system by the platform builder".
Here is the problem, these manufacturers are just ignoring it. It should be there, it's simply not implemented.
Besides, there is a second irritating thing on many of the devices I've testet: They use the Log in the wrong way and log verbose messages as erros which is really a pain.
Anyway, this is a hint before buying no name hardware.
I'm still looking for a way to get this done. I think the only way is to get the frames and save them to the texture myself.
The performance will be really bad, it must however work.
- Marco (marco3d - originally)
