Screen Dark working with FBOs
Note: This was originally posted on 7th November 2010 at http://forums.arm.com
Hi Guys,
Trying to port an akready well running Sw from Fedora PC to the Mali400 on ST7108 chip, with GLES-2.0, I got a problem working with Framebuffer Objects.
Everything is ok, debugging ok, framebuffer objects completes, no errors, but the screen remains completely dark.
My environment on Mali/ST7108 is OK, other applications can run nicely.
But I think to have not completely understood (or better: not understood at all) how to set display and surfaces while working woth FBOs (maybe the problem could be also found somewhere else)
Basic setting is more or less as below, where I have put only the relevant setting and call for Display and Surfaces.
In does seem that the eglSwapBuffers does't work at all while working with FBOs
(even a monocolor screen cannot be seen...).
In contrast, while working out of FBOs, everything seems to be ok.
After binding with glBindFramebuffer(GL_FRAMEBUFFER,0), then everything is working and can be displayed.
In contrast, after glBindFramebuffer(GL_FRAMEBUFFER, framebuffer), I cannot see anything after he eglSwapBuffers, even if the debug seems to be ok.
Could someone pls help me in giving me suggestions on how to properly set Display and Surfaces?
Does there is a running examples while using FBOs on ST7108 chip?
Thanks a lot in advance for this
(here below I have just put a rough skeleton of the used code)
EGLDisplay eglDisplay = 0;
EGLSurface eglSurface = 0;
EGLint major, minor, num_configs;
eglDisplay = eglGetDisplay(EGL_DEFAULT_DISPLAY));
eglInitialize(eglDisplay, &major, &minor);
eglBindAPI(EGL_OPENGL_ES_API);
eglChooseConfig(eglDisplay, configAttribs, &eglConfig, 1, &num_configs);
eglSurface = eglCreateWindowSurface(eglDisplay, eglConfig, NULL, NULL);
eglContext = eglCreateContext(eglDisplay, eglConfig, NULL, contextAttribs)));
eglMakeCurrent(eglDisplay, eglSurface, eglSurface, eglContext);
egl_setup(&eglDisplay,&eglSurface);
GLuint framebuffer;
GLuint depthRenderbuffer;
GLuint texture;
glGenFramebuffers(1, &framebuffer);
glGenRenderbuffers(1, &depthRenderbuffer);
glGenTextures(1, &texture);
glBindTexture(GL_TEXTURE_2D, texture);
glTexImage2D(GL_TEXTURE_2D, 0, GL_RGB, texWidth, texHeight, 0, GL_RGB, GL_UNSIGNED_SHORT_5_6_5, NULL);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER, GL_LINEAR);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER, GL_LINEAR);
glBindRenderbuffer(GL_RENDERBUFFER, depthRenderbuffer);
glRenderbufferStorage(GL_RENDERBUFFER, GL_DEPTH_COMPONENT16, texWidth, texHeight);
glBindFramebuffer(GL_FRAMEBUFFER, framebuffer);
glFramebufferTexture2D(GL_FRAMEBUFFER, GL_COLOR_ATTACHMENT0, GL_TEXTURE_2D, texture, 0);
glFramebufferRenderbuffer(GL_FRAMEBUFFER, GL_DEPTH_ATTACHMENT, GL_RENDERBUFFER, depthRenderbuffer);
Switch (glCheckFramebufferStatus(GL_FRAMEBUFFER))
case GL_FRAMEBUFFER_COMPLETE:
fprintf(stdout, "\n o Framebuffer Complete");
break;
GLCheckError(glClearColor(1.0f, 0.0f, 0.0f, 1.0f));
eglSwapBuffers(eglDisplay, eglSurface);
// glBindFramebuffer(GL_FRAMEBUFFER,0);
Many Thanks
  • Note: This was originally posted on 8th November 2010 at http://forums.arm.com
    Hi Guys,
    Perhaps I've misunderstood the problem you're facing but it looks like what you're trying to do is render to an FBO and then swap the contents of that FBO to the display surface.
    This isn't really what FBOs are for. The EGL surface essentially has its own framebuffer, and when you call glBindFramebuffer(GL_FRAMEBUFFER,0) this is telling the GLES contexrt to render to that.
    When you call glBindFramebuffer(GL_FRAMEBUFFER, framebuffer) the GLES context will start writing to a different surface in memory, and doesn't touch the area of memory which is displayed when you call eglSwapBuffers.
    Usually the reason you would use a frame buffer object in this way is something like:
    glFramebufferTexture2D(GL_FRAMEBUFFER,GL_COLOR_ATTACHMENT0,GL_TEXTURE_2D,texture,0);
    // render texture details to frame buffer
    glBindFramebuffer(GL_FRAMEBUFFER, 0)
    // render objects using texture
    eglSwapbuffers(display, surface)
    This allows you to have, for example, a texture showing the scene from a different angle, for if you wanted to have a virtual environment with a screen showing what a camera elsewhere in the scene sees.
    If you don't bind to buffer 0, the rendering done at that point will just go into the texture, and there'll be nothing worth swapping.
    Does that sound like what you're trying to achieve?
    -Stacy
  • Note: This was originally posted on 10th November 2010 at http://forums.arm.com
    Thanks Stacy for your input,
    Yes in fact the intention was to port to the STi7108 chip an algorithm already running on a commercial GPU, createing a novel picture by interpolating among a set of real ones taken from very different viewpoints as if it was taken from a virtual position within the scene's space.
    The algorithm uses the FBOs to render-to-textures the intermediate results of the pipeline, in a multi-pass fashion, so that each step saves its output into a texture by an FBO and the next reads and processes it again.
    The code compiles and seems to run completely on the Mali, but there are then problems in viewing to the screen.
    Waiting for any suggestion,
    Thanks & Best Regards
    Does this mean you have a number of FBOs, each bound to a different texture, and the final pass renders all those textures into the scene? Or does each pass render the last result onto the next texture, and only the final pass is drawn to the screen?
    Either way, your final pass has to be drawn to the egl surface, not a frame buffer object.
    If you still have a frame buffer object bound when you do your final pass, all the drawcalls will render to that FBO, which won't go to the screen when you swap buffers.
    -Stacy
  • Note: This was originally posted on 11th November 2010 at http://forums.arm.com
    Hi again Stacy,
    The following is done: at every pass it reads from an FBO, then it process and write in an FBO; only the last one write in a video.
    Best Regards,
  • Note: This was originally posted on 15th November 2010 at http://forums.arm.com
    ...And you say that final pass where you render out onto the video surface is coming up blank.
    In an earlier post you said that it came up blank when you had a framebuffer bound with glBindFramebuffer(GL_FRAMEBUFFER, framebuffer), but not when you first called glBindFramebuffer(GL_FRAMEBUFFER, 0).
    This is because if you don't unbind the framebuffer with glBindFramebuffer(GL_FRAMEBUFFER, 0), it tries to render onto the currently bound frame buffer, not to the video surface.
    I suppose the question I should be asking is, why do you want to keep the framebuffer bound? After you've attached it to a texture, the only reason to keep a framebuffer bound is to render to it.
    -Stacy
  • Note: This was originally posted on 9th August 2011 at http://forums.arm.com
    Stacy - I'm fairly new to OpenGL and have been trying to learn exactly this kind of overall usage model for when to use FBOs and how they can improve either graphics or memory performance (or both).  My application will essentially be operating on textures - with a background texture surface filling the "window" and a number of smaller textures being "animated" on top of that - potentially with changes in alpha as well as of course position, rotation, size, etc.  This functionality represents only a small portion of the OpenGL|ES functionality, and yet I still haven't found a good resource to learn from on how to optimize this kind of drawing.
    The kinds of questions I have range from some basics such as how to account for the number of texture units when optimizing (i.e. is it better to use only one?), to understanding when the underlying memory transfers between application and GPU occur (in terms of APIs or other evolutions) and what the performance implications of these are, etc.  I have also heard that some kinds of ops (e.g. DEPTH testing) will slow down texture processing, so I'd like to understand if there are things like this that I should stay away from - given more than one way to do what I need to do.  Any general advice for a newbie trying to get up to speed on these sorts of topics?
    Thanks very much.
  • Note: This was originally posted on 22nd August 2011 at http://forums.arm.com
    Sounds like you're writing a sprite engine there.
    FBOs arent really used much for that kind of thing, unless you're intending to render a 3D animated model to an FBO then use that FBO to draw it as a sprite.
    The usual use for FBOs is either to act as a reflection modulated by surface ripples, alternate view mapped to a surface (like a security monitor in a scene showing another location) or some kind of lighting/shadow effect (using depth values for framebuffer shadows or rendering a smaller version of a scene with lighting altered to act as an interpolated additive glow)
    The overhead involved in using FBOs for such purposes is mostly the fragment shader cycles required to render the scene onto the FBO as well as the scene going to the main framebuffer. In terms of memory footprint it's pretty much the same as a texture.
    None of these things are anything to do with FBOs, so I may see if I can have this bit of the thread broken onto its own topic by moderators. Until then, I can answer it here.
    The question on texture units has the most in depth answer, so I'll leave that one until last.
    Regarding the the underlying transfers, unless you plan on using the UMP drivers (universal memory provider) the point at which the big transfer happens is when you call glTexImage2D. It's in the GL specification that as soon as this function call has completed the CPU can drop its copy of the texture data. Depending on the memory mapping implementation of the GPU, in some cases it may be copied into the driver, but the application itself no longer needs to store this data. Textures can be loaded like this at startup time and you don't need to transfer them on a per frame basis.
    Depth testing slowing down texture processing may have been a problem back in the days of software renderers but on modern graphics hardware it's been optimised to the point where the cost is negligible compared to the benefits. For example, if you use the depth testing to render all your animated objects first and then do the background pass with a depth value applied, it is measurably faster, because it doesn't have to look up texels for the parts of the background covered by the animated sprites.
    The alpha channel is the real performance drain if you're not careful with it. As described above, by rendering things from front to back you can reduce texture lookups and improve your performance, but this won't work if you have semi-transparent sprites. A semi-transparent sprite in the foreground will still write to the depth buffer and the background can't be rendered behind it.
    If your sprites have only fully transparent and fully opaque pixels, you can still render front to back by telling transparent fragments to call discard in the fragment shader, preventing it from writing to the depth buffer.
    If however you have antialiasing to transparency or semi-transparent pixels, you'lll have to render what's behind them first, so it can show through.
    The benefits of using single or multiple texture units are more complicated.
    When textures are uploaded to the Mali GPU by the driver, they are stored in a way which makes them cache nicely regardless of what angle you sample them at. As such when you rotate this texture, the scanlines drawn by the fragment shader will stil be able to use cached texture blocks more often, which is good for performance. If on the other hand you need to sample two completely different places from the same texture as part of the same fragment, the caching will miss, because it is swapping between places in the texture, such as using one texture as a colour map and another as a normal map. In this case they are best arranged into separate texture units.
    However, for the purposes you're describing it sounds like you'd want to arrange a texture like a sprite sheet, which is usually referred to as a texture atlas. Making a texture atlas is efficient because there's a small overhead in texture state changes. If you wanted to draw 20 different animated sprites over the top of your background, switching textures for every one is time consuming. Additionally, using a separate draw call for every sprite takes its toll.
    If you batch your sprites together by arranging them onto one texture atlas they can be rendered in a single drawcall by generating the correct vertices every frame.
    That's about as much detail as I can get into without diagrams. If this is something you'd be interested in a deeper description of let me know and I'll see if I can get authorisation for a sample code based on these techniques. Some of the points covered here are already touched upon in the other sample code on malideveloper.com .
    Thanks very much.
    You're welcome!
    -Stacy
  • Note: This was originally posted on 12th September 2011 at http://forums.arm.com
    Hi there. I'm having a similar issue.
    Like the original poster, I create the FBO, bind it to a texture, check the status to make sure it's framebuffer complete, then set it to the rendering buffer, call drawelements, and I get GL_INVALID_FRAMEBUFFER_OPERATION error. Bit of a mystery since I check the completeness status on the line immediately prior to the draw call.
    Do the settings on the texture object matter, e.g. repeat/linear/reflect. Does Mali require me to specify a depth or stencil buffer? Does it require an alpha channel?
    This code works on Tegra2 and Adreno 205. Not sure why Mali doesn't like it.
    I've also noticed that this graphics unit seems to have trouble with the first texture write to the display. I'll have to go into that in detail in another thread when I'm ready to deal with it.
    Cheers!
  • Note: This was originally posted on 13th September 2011 at http://forums.arm.com
    Without knowing more about what you're trying to do or what hardware you're using it's hard to really answer this. It sounds like you might be using the texture in the scene with the FBO still bound, so it's trying to write to the framebuffer using content from the frame buffer. Is that what you're doing?
    It doesn't require a depth or stencil buffer but if you want to use depth or stencil features you'll need to have one bound.
    There are certain actions with frame buffers  (such as binding an FBO to a texture and renderbuffer simultaneously, which it sounds like you might be doing) which have undefined or poorly defined behaviours in the spec. Depending on your GPU (or more specifically how strict the drivers are) some things will error, others will fail silently and simply have that texture appear messed up.
    I can't really give a more specific answer without details of what you're doing...
    -Stacy
    -Stacy
    Hi Stacy!
    Thanks for your reply. I was able to solve this on my own. Apparently Mali requires that you specify the data type GL_UNSIGNED_SHORT_5_6_5 when creating an empty texture object rather than GL_UNSIGNED_BYTE.
    I'm still left with the other problem I described in the other thread if you would care to address that. For that one I've provided you with some sample code that works on other hardware.
    Cheers...
    Sorry, I just reviewed my other post and it was the same as the one in this thread. I'll elaborate on the 'other' problem here.
    Having sorted out the error, I'm still left with the same problem reported by the original poster in this thread. I can now render to the texture object without any complaints from OpenGL ES 2, but when I then attempt to use that texture to paint a polygon in a later operation it comes up black.
    In answer to your question regarding usage, I create the FBO and texture object at startup and bind them together. Periodically, I set the FBO as the target of the draw commands (glSetFramebuffer(xxx) ), draw into the texture, then set the draw target back to the default framebuffer (glSetFramebuffer(0)). At this point I call another draw command that uses my texture as an input. This draw command results in black anywhere that the texture should have been rendered.
    I do not unbind the FBO I created from the texture. Should I do this?
    The device I'm working with in this case is the Samsung Galaxy S 2.
    Last bit of info...I'm not attaching any renderbuffers, just the texture object created with no data.
    The example code I provided in the other posting should demostrate the problem.
    Cheers...
