Device driver API mismatch - LibEGL
Note: This was originally posted on 19th March 2013 at http://forums.arm.com
Hellor there!! How are you? This is my first post here!!
I have a BIG problem a few days ago! I have a ODROID-PC with a Exynos 4210 (Cortex A9 - Mali400) and I compiled Android ICS from AOSP repository and everything was fine ... or really not! Haha.. I don't have video signal and I think that the problem is with the OpenGL ES!
So ...  the Android logcat get this,
D/libEGL  ( 1252): loaded /system/lib/egl/libEGL_mali.so
D/libEGL  ( 1252): loaded /system/lib/egl/libGLESv1_CM_mali.so
D/libEGL  ( 1252): loaded /system/lib/egl/libGLESv2_mali.so
E/        ( 1252): Device driver API mismatch
E/        ( 1252): Device driver API version: 9
E/        ( 1252): User space API version: 10
D/        ( 1252): mali: REVISION=Linux-r2p4-02rel0 BUILD_DATE=Mon May 14 20:33:23 KST 2012
W/libEGL  ( 1252): 0: eglInitialize(0x1) failed (EGL_BAD_ALLOC)
E/libEGL  ( 1252): initialize:290 error 3001 (EGL_NOT_INITIALIZED)
E/libEGL  ( 1252): validate_display:190 error 3001 (EGL_NOT_INITIALIZED)
F/libc    ( 1252): Fatal signal 11 (SIGSEGV) at 0xdeadbaad (code=1)
I/DEBUG   ( 1123): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
I/DEBUG   ( 1123): Build fingerprint: 'Android/odroidpc/odroidpc:4.0.4/IMM76L/eng.ahestevenz.20130312.171353:eng/test-keys'
If I have understood well .. the problem is: Device driver API mismatch, but I don't know how to resolve this!
If somebody has any idea why I'm getting this I would really appreciate your help!
Thanks in advance!
Ariel Hernández
  • Note: This was originally posted on 20th March 2013 at http://forums.arm.com
    Hi Ariel,
    It seems that the Kernel driver does not match the version of the userspace binaries that you are using (v of lib*_mali.so != v of mali.ko). Did you obtain the userspace binaries as part of a proprietary bundle? If so the userspace is fixed, but it should be possible to swap out the kernel side for the correct version, available from malideveloper.com.
    Thanks,
    Chris
  • Note: This was originally posted on 8th April 2013 at http://forums.arm.com
    First of all I'm sorry for the late reply!!
    Thank you so much for your answer!! The problem was a mismatch between libraries and kernel driver.
    Regards,
    Ariel Hernández
    Hi Ariel,
    Thanks,
    Chris
