I am also facing this problem, is there any workaround present to fix the geometry selection problem?
Hi Projekt2501!Are you following the same procedure I outlined in my post above? I can't reproduce the issue on any platform I've tried, but I wonder if I might be doing something different to you?
!ENTRY org.eclipse.jface 4 0 2011-10-19 10:43:33.422!MESSAGE java.lang.NullPointerException!STACK 0java.lang.NullPointerException at com.arm.mali.shaderdebugger.preview.PreviewModel.setLastMRIConnection(PreviewModel.java:677) at com.arm.mali.visualtools.preferences.MRIPreferencePage.saveConnectionInfo(MRIPreferencePage.java:462) at com.arm.mali.visualtools.preferences.MRIPreferencePage.performOk(MRIPreferencePage.java:447) at org.eclipse.jface.preference.PreferenceDialog$13.run(PreferenceDialog.java:964) at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42) at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49) at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175) at org.eclipse.jface.preference.PreferenceDialog.okPressed(PreferenceDialog.java:944) at org.eclipse.ui.internal.dialogs.FilteredPreferenceDialog.okPressed(FilteredPreferenceDialog.java:447) at org.eclipse.ui.internal.dialogs.WorkbenchPreferenceDialog.okPressed(WorkbenchPreferenceDialog.java:171) at org.eclipse.jface.preference.PreferenceDialog.buttonPressed(PreferenceDialog.java:233) at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624) at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:240) at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84) at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053) at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165) at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754) at org.eclipse.jface.window.Window.runEventLoop(Window.java:825) at org.eclipse.jface.window.Window.open(Window.java:801) at org.eclipse.ui.internal.dialogs.WorkbenchPreferenceDialog.open(WorkbenchPreferenceDialog.java:215) at org.eclipse.ui.internal.handlers.ShowPreferencePageHandler.execute(ShowPreferencePageHandler.java:54) at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293) at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476) at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508) at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169) at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:241) at org.eclipse.ui.internal.actions.CommandAction.runWithEvent(CommandAction.java:157) at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584) at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501) at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411) at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84) at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053) at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165) at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754) at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696) at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660) at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494) at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332) at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667) at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149) at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577) at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
!ENTRY org.eclipse.ui.workbench 4 0 2011-10-19 10:47:56.957!MESSAGE Widget is disposed!STACK 0org.eclipse.swt.SWTException: Widget is disposed at org.eclipse.swt.SWT.error(SWT.java:4282) at org.eclipse.swt.SWT.error(SWT.java:4197) at org.eclipse.swt.SWT.error(SWT.java:4168) at org.eclipse.swt.widgets.Widget.error(Widget.java:468) at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:340) at org.eclipse.swt.widgets.Label.getImage(Label.java:238) at com.arm.mali.shaderdebugger.preview.ShaderPreview.dispose(ShaderPreview.java:110) at org.eclipse.ui.internal.WorkbenchPartReference.doDisposePart(WorkbenchPartReference.java:737) at org.eclipse.ui.internal.ViewReference.doDisposePart(ViewReference.java:104) at org.eclipse.ui.internal.WorkbenchPartReference.dispose(WorkbenchPartReference.java:684) at org.eclipse.ui.internal.WorkbenchPage.disposePart(WorkbenchPage.java:1797) at org.eclipse.ui.internal.WorkbenchPage.partRemoved(WorkbenchPage.java:1789) at org.eclipse.ui.internal.ViewFactory.releaseView(ViewFactory.java:257) at org.eclipse.ui.internal.Perspective.dispose(Perspective.java:292) at org.eclipse.ui.internal.WorkbenchPage.dispose(WorkbenchPage.java:1868) at org.eclipse.ui.internal.WorkbenchWindow.closeAllPages(WorkbenchWindow.java:887) at org.eclipse.ui.internal.WorkbenchWindow.hardClose(WorkbenchWindow.java:1722) at org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchWindow.java:730) at org.eclipse.ui.internal.WorkbenchWindow.access$0(WorkbenchWindow.java:715) at org.eclipse.ui.internal.WorkbenchWindow$5.run(WorkbenchWindow.java:860) at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70) at org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindow.java:858) at org.eclipse.jface.window.WindowManager.close(WindowManager.java:109) at org.eclipse.ui.internal.Workbench$18.run(Workbench.java:1109) at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42) at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:1106) at org.eclipse.ui.internal.Workbench.access$15(Workbench.java:1035) at org.eclipse.ui.internal.Workbench$25.run(Workbench.java:1279) at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70) at org.eclipse.ui.internal.Workbench.close(Workbench.java:1277) at org.eclipse.ui.internal.Workbench.close(Workbench.java:1249) at org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchWindow.java:727) at org.eclipse.ui.internal.WorkbenchWindow.access$0(WorkbenchWindow.java:715) at org.eclipse.ui.internal.WorkbenchWindow$5.run(WorkbenchWindow.java:860) at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70) at org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindow.java:858) at org.eclipse.jface.window.Window.handleShellCloseEvent(Window.java:741) at org.eclipse.jface.window.Window$3.shellClosed(Window.java:687) at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:98) at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84) at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053) at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077) at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1062) at org.eclipse.swt.widgets.Decorations.closeWidget(Decorations.java:308) at org.eclipse.swt.widgets.Decorations.WM_CLOSE(Decorations.java:1677) at org.eclipse.swt.widgets.Control.windowProc(Control.java:4530) at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:341) at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1610) at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2061) at org.eclipse.swt.widgets.Display.windowProc(Display.java:4972) at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method) at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:2526) at org.eclipse.swt.widgets.Shell.callWindowProc(Shell.java:498) at org.eclipse.swt.widgets.Control.windowProc(Control.java:4623) at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:341) at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1610) at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2061) at org.eclipse.swt.widgets.Display.windowProc(Display.java:4972) at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method) at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:2526) at org.eclipse.swt.widgets.Shell.callWindowProc(Shell.java:498) at org.eclipse.swt.widgets.Control.windowProc(Control.java:4623) at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:341) at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1610) at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2061) at org.eclipse.swt.widgets.Display.windowProc(Display.java:4972) at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method) at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2531) at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3752) at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696) at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660) at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494) at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332) at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667) at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149) at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577) at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
