Guys, hello, but your studio does not start (I have OSX) and after installation, (I downloaded and unpacked) I registered the paths in the file as it was mentioned in the readme. After that, I tried to start (by writing sudo spctl --master-disable first) to the streamline and the Graphics analyzer - nothing started: the streamliner got lost and disappeared, and the analyzer showed the following error
After that, I read how to correct this error and put the following line into info.plist:
<key>Eclipse</key> <array> <!-- to use a specific Java version (instead of the platform's default) uncomment one of the following options, or add a VM found via $/usr/libexec/java_home -V <string>-vm</string><string>/System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Commands/java</string> <string>-vm</string><string>/Library/Java/JavaVirtualMachines/1.8.0.jdk/Contents/Home/bin/java</string> --> <string>-keyring</string>
I rewrote this way:
<key>Eclipse</key><array>
<string>-vm</string><string>/Library/Java/JavaVirtualMachines/jdk-10.jdk/Contents/Home/bin</string>--><!-- to use a specific Java version (instead of the platform's default) uncomment one of the following options,or add a VM found via $/usr/libexec/java_home -V<string>-vm</string><string>/System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Commands/java</string><string>-keyring</string>
, after that the program did not work, but showed a different error, the program recorded it in the log, which I attached to this post. But nothing has earned. Here is a problem
!SESSION 2019-04-20 15:23:18.257 ----------------------------------------------- eclipse.buildId=unknown java.version=1.8.0_60 java.vendor=Oracle Corporation BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_US Framework arguments: -keyring /Users/sergeiloskutnikov/.eclipse_keyring Command-line arguments: -os macosx -ws cocoa -arch x86_64 -data @user.home/.aga_workspace_5.2.0 -keyring /Users/sergeiloskutnikov/.eclipse_keyring !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-04-20 15:23:22.428 !MESSAGE Unable to acquire PluginConverter service during generation for: /private/var/folders/f1/f5b0cbrn3kz08pw4sh_l64h40000gn/T/AppTranslocation/63B0A678-8588-401B-A6B3-C364AA629710/d/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar. !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-04-20 15:23:22.466 !MESSAGE Unable to acquire PluginConverter service during generation for: /private/var/folders/f1/f5b0cbrn3kz08pw4sh_l64h40000gn/T/AppTranslocation/63B0A678-8588-401B-A6B3-C364AA629710/d/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar. !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-04-20 15:23:22.497 !MESSAGE Unable to acquire PluginConverter service during generation for: /private/var/folders/f1/f5b0cbrn3kz08pw4sh_l64h40000gn/T/AppTranslocation/63B0A678-8588-401B-A6B3-C364AA629710/d/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar. !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-04-20 15:23:22.523 !MESSAGE Unable to acquire PluginConverter service during generation for: /private/var/folders/f1/f5b0cbrn3kz08pw4sh_l64h40000gn/T/AppTranslocation/63B0A678-8588-401B-A6B3-C364AA629710/d/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar. !SESSION 2019-05-26 10:55:00.500 ----------------------------------------------- eclipse.buildId=unknown java.version=10 java.vendor=Oracle Corporation BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_RU Framework arguments: -keyring /Users/sergeiloskutnikov/.eclipse_keyring Command-line arguments: -os macosx -ws cocoa -arch x86_64 -data @user.home/.aga_workspace_5.2.0 -keyring /Users/sergeiloskutnikov/.eclipse_keyring !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 10:55:05.511 !MESSAGE Unable to acquire PluginConverter service during generation for: /private/var/folders/f1/f5b0cbrn3kz08pw4sh_l64h40000gn/T/AppTranslocation/CA444C30-D5EA-4457-B5E8-6DD8F41236E2/d/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar. !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 10:55:05.571 !MESSAGE Unable to acquire PluginConverter service during generation for: /private/var/folders/f1/f5b0cbrn3kz08pw4sh_l64h40000gn/T/AppTranslocation/CA444C30-D5EA-4457-B5E8-6DD8F41236E2/d/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar. !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 10:55:05.604 !MESSAGE Unable to acquire PluginConverter service during generation for: /private/var/folders/f1/f5b0cbrn3kz08pw4sh_l64h40000gn/T/AppTranslocation/CA444C30-D5EA-4457-B5E8-6DD8F41236E2/d/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar. !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 10:55:05.634 !MESSAGE Unable to acquire PluginConverter service during generation for: /private/var/folders/f1/f5b0cbrn3kz08pw4sh_l64h40000gn/T/AppTranslocation/CA444C30-D5EA-4457-B5E8-6DD8F41236E2/d/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar. !ENTRY org.eclipse.osgi 4 0 2019-05-26 10:55:06.860 !MESSAGE Application error !STACK 1 org.eclipse.e4.core.di.InjectionException: java.lang.NoClassDefFoundError: javax/annotation/PostConstruct at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:386) at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:294) at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162) at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultHeadlessContext(E4Application.java:490) at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultContext(E4Application.java:504) at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:203) at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:632) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:336) at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:610) at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:148) at com.arm.mgd.ui.Application.start(Application.java:112) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.base/java.lang.reflect.Method.invoke(Method.java:564) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610) at org.eclipse.equinox.launcher.Main.run(Main.java:1519) Caused by: java.lang.NoClassDefFoundError: javax/annotation/PostConstruct at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:151) at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:375) ... 22 more Caused by: java.lang.ClassNotFoundException: javax.annotation.PostConstruct cannot be found by org.eclipse.e4.core.di_1.6.1.v20160712-0927 at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:410) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:372) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:364) at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:161) at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:499) ... 24 more !ENTRY org.eclipse.e4.ui.workbench 4 0 2019-05-26 10:55:06.870 !MESSAGE FrameworkEvent ERROR !STACK 0 java.lang.NoClassDefFoundError: javax/annotation/PreDestroy at org.eclipse.e4.core.internal.di.InjectorImpl.disposed(InjectorImpl.java:426) at org.eclipse.e4.core.internal.di.Requestor.disposed(Requestor.java:154) at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:78) at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:111) at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.handleInvalid(TrackableComputationExt.java:74) at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:176) at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.dispose(EclipseContextOSGi.java:106) at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.bundleChanged(EclipseContextOSGi.java:139) at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:903) at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:156) at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) at org.eclipse.osgi.container.Module.doStop(Module.java:634) at org.eclipse.osgi.container.Module.stop(Module.java:498) at org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:202) at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule$1.run(EquinoxBundle.java:165) at java.base/java.lang.Thread.run(Thread.java:844) Caused by: java.lang.ClassNotFoundException: javax.annotation.PreDestroy cannot be found by org.eclipse.e4.core.di_1.6.1.v20160712-0927 at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:410) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:372) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:364) at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:161) at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:499) ... 21 more !SESSION 2019-05-26 11:00:37.083 ----------------------------------------------- eclipse.buildId=unknown java.version=10 java.vendor=Oracle Corporation BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_RU Framework arguments: -keyring /Users/sergeiloskutnikov/.eclipse_keyring Command-line arguments: -os macosx -ws cocoa -arch x86_64 -data @user.home/.aga_workspace_5.2.0 -keyring /Users/sergeiloskutnikov/.eclipse_keyring !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 11:00:40.651 !MESSAGE Unable to acquire PluginConverter service during generation for: /private/var/folders/f1/f5b0cbrn3kz08pw4sh_l64h40000gn/T/AppTranslocation/D92FA5A1-9F04-41BC-A58F-D34FC610A58B/d/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar. !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 11:00:40.695 !MESSAGE Unable to acquire PluginConverter service during generation for: /private/var/folders/f1/f5b0cbrn3kz08pw4sh_l64h40000gn/T/AppTranslocation/D92FA5A1-9F04-41BC-A58F-D34FC610A58B/d/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar. !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 11:00:40.735 !MESSAGE Unable to acquire PluginConverter service during generation for: /private/var/folders/f1/f5b0cbrn3kz08pw4sh_l64h40000gn/T/AppTranslocation/D92FA5A1-9F04-41BC-A58F-D34FC610A58B/d/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar. !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 11:00:40.762 !MESSAGE Unable to acquire PluginConverter service during generation for: /private/var/folders/f1/f5b0cbrn3kz08pw4sh_l64h40000gn/T/AppTranslocation/D92FA5A1-9F04-41BC-A58F-D34FC610A58B/d/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar. !ENTRY org.eclipse.osgi 4 0 2019-05-26 11:00:41.766 !MESSAGE Application error !STACK 1 org.eclipse.e4.core.di.InjectionException: java.lang.NoClassDefFoundError: javax/annotation/PostConstruct at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:386) at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:294) at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162) at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultHeadlessContext(E4Application.java:490) at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultContext(E4Application.java:504) at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:203) at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:632) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:336) at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:610) at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:148) at com.arm.mgd.ui.Application.start(Application.java:112) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.base/java.lang.reflect.Method.invoke(Method.java:564) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610) at org.eclipse.equinox.launcher.Main.run(Main.java:1519) Caused by: java.lang.NoClassDefFoundError: javax/annotation/PostConstruct at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:151) at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:375) ... 22 more Caused by: java.lang.ClassNotFoundException: javax.annotation.PostConstruct cannot be found by org.eclipse.e4.core.di_1.6.1.v20160712-0927 at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:410) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:372) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:364) at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:161) at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:499) ... 24 more !ENTRY org.eclipse.e4.ui.workbench 4 0 2019-05-26 11:00:41.776 !MESSAGE FrameworkEvent ERROR !STACK 0 java.lang.NoClassDefFoundError: javax/annotation/PreDestroy at org.eclipse.e4.core.internal.di.InjectorImpl.disposed(InjectorImpl.java:426) at org.eclipse.e4.core.internal.di.Requestor.disposed(Requestor.java:154) at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:78) at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:111) at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.handleInvalid(TrackableComputationExt.java:74) at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:176) at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.dispose(EclipseContextOSGi.java:106) at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.bundleChanged(EclipseContextOSGi.java:139) at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:903) at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:156) at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) at org.eclipse.osgi.container.Module.doStop(Module.java:634) at org.eclipse.osgi.container.Module.stop(Module.java:498) at org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:202) at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule$1.run(EquinoxBundle.java:165) at java.base/java.lang.Thread.run(Thread.java:844) Caused by: java.lang.ClassNotFoundException: javax.annotation.PreDestroy cannot be found by org.eclipse.e4.core.di_1.6.1.v20160712-0927 at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:410) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:372) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:364) at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:161) at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:499) ... 21 more !SESSION 2019-05-26 11:06:58.701 ----------------------------------------------- eclipse.buildId=unknown java.version=10 java.vendor=Oracle Corporation BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_RU Framework arguments: -keyring /Users/sergeiloskutnikov/.eclipse_keyring Command-line arguments: -os macosx -ws cocoa -arch x86_64 -data @user.home/.aga_workspace_5.2.0 -keyring /Users/sergeiloskutnikov/.eclipse_keyring !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 11:07:02.216 !MESSAGE Unable to acquire PluginConverter service during generation for: /private/var/folders/f1/f5b0cbrn3kz08pw4sh_l64h40000gn/T/AppTranslocation/D6390C76-0C01-4A0E-9556-003A9CF51F84/d/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar. !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 11:07:02.271 !MESSAGE Unable to acquire PluginConverter service during generation for: /private/var/folders/f1/f5b0cbrn3kz08pw4sh_l64h40000gn/T/AppTranslocation/D6390C76-0C01-4A0E-9556-003A9CF51F84/d/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar. !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 11:07:02.305 !MESSAGE Unable to acquire PluginConverter service during generation for: /private/var/folders/f1/f5b0cbrn3kz08pw4sh_l64h40000gn/T/AppTranslocation/D6390C76-0C01-4A0E-9556-003A9CF51F84/d/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar. !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 11:07:02.338 !MESSAGE Unable to acquire PluginConverter service during generation for: /private/var/folders/f1/f5b0cbrn3kz08pw4sh_l64h40000gn/T/AppTranslocation/D6390C76-0C01-4A0E-9556-003A9CF51F84/d/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar. !ENTRY org.eclipse.osgi 4 0 2019-05-26 11:07:03.357 !MESSAGE Application error !STACK 1 org.eclipse.e4.core.di.InjectionException: java.lang.NoClassDefFoundError: javax/annotation/PostConstruct at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:386) at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:294) at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162) at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultHeadlessContext(E4Application.java:490) at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultContext(E4Application.java:504) at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:203) at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:632) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:336) at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:610) at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:148) at com.arm.mgd.ui.Application.start(Application.java:112) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.base/java.lang.reflect.Method.invoke(Method.java:564) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610) at org.eclipse.equinox.launcher.Main.run(Main.java:1519) Caused by: java.lang.NoClassDefFoundError: javax/annotation/PostConstruct at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:151) at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:375) ... 22 more Caused by: java.lang.ClassNotFoundException: javax.annotation.PostConstruct cannot be found by org.eclipse.e4.core.di_1.6.1.v20160712-0927 at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:410) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:372) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:364) at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:161) at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:499) ... 24 more !ENTRY org.eclipse.e4.ui.workbench 4 0 2019-05-26 11:07:03.366 !MESSAGE FrameworkEvent ERROR !STACK 0 java.lang.NoClassDefFoundError: javax/annotation/PreDestroy at org.eclipse.e4.core.internal.di.InjectorImpl.disposed(InjectorImpl.java:426) at org.eclipse.e4.core.internal.di.Requestor.disposed(Requestor.java:154) at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:78) at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:111) at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.handleInvalid(TrackableComputationExt.java:74) at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:176) at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.dispose(EclipseContextOSGi.java:106) at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.bundleChanged(EclipseContextOSGi.java:139) at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:903) at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:156) at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) at org.eclipse.osgi.container.Module.doStop(Module.java:634) at org.eclipse.osgi.container.Module.stop(Module.java:498) at org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:202) at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule$1.run(EquinoxBundle.java:165) at java.base/java.lang.Thread.run(Thread.java:844) Caused by: java.lang.ClassNotFoundException: javax.annotation.PreDestroy cannot be found by org.eclipse.e4.core.di_1.6.1.v20160712-0927 at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:410) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:372) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:364) at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:161) at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:499) ... 21 more !SESSION 2019-05-26 12:06:06.122 ----------------------------------------------- eclipse.buildId=unknown java.version=10 java.vendor=Oracle Corporation BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_RU Framework arguments: -keyring /Users/sergeiloskutnikov/.eclipse_keyring Command-line arguments: -os macosx -ws cocoa -arch x86_64 -data @user.home/.aga_workspace_5.2.0 -keyring /Users/sergeiloskutnikov/.eclipse_keyring !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 12:06:11.253 !MESSAGE Unable to acquire PluginConverter service during generation for: /private/var/folders/f1/f5b0cbrn3kz08pw4sh_l64h40000gn/T/AppTranslocation/1C516BFA-22F7-45AC-B18C-70CDFAE9524B/d/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar. !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 12:06:11.297 !MESSAGE Unable to acquire PluginConverter service during generation for: /private/var/folders/f1/f5b0cbrn3kz08pw4sh_l64h40000gn/T/AppTranslocation/1C516BFA-22F7-45AC-B18C-70CDFAE9524B/d/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar. !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 12:06:11.332 !MESSAGE Unable to acquire PluginConverter service during generation for: /private/var/folders/f1/f5b0cbrn3kz08pw4sh_l64h40000gn/T/AppTranslocation/1C516BFA-22F7-45AC-B18C-70CDFAE9524B/d/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar. !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 12:06:11.361 !MESSAGE Unable to acquire PluginConverter service during generation for: /private/var/folders/f1/f5b0cbrn3kz08pw4sh_l64h40000gn/T/AppTranslocation/1C516BFA-22F7-45AC-B18C-70CDFAE9524B/d/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar. !ENTRY org.eclipse.osgi 4 0 2019-05-26 12:06:12.493 !MESSAGE Application error !STACK 1 org.eclipse.e4.core.di.InjectionException: java.lang.NoClassDefFoundError: javax/annotation/PostConstruct at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:386) at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:294) at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162) at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultHeadlessContext(E4Application.java:490) at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultContext(E4Application.java:504) at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:203) at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:632) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:336) at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:610) at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:148) at com.arm.mgd.ui.Application.start(Application.java:112) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.base/java.lang.reflect.Method.invoke(Method.java:564) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610) at org.eclipse.equinox.launcher.Main.run(Main.java:1519) Caused by: java.lang.NoClassDefFoundError: javax/annotation/PostConstruct at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:151) at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:375) ... 22 more Caused by: java.lang.ClassNotFoundException: javax.annotation.PostConstruct cannot be found by org.eclipse.e4.core.di_1.6.1.v20160712-0927 at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:410) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:372) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:364) at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:161) at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:499) ... 24 more !ENTRY org.eclipse.e4.ui.workbench 4 0 2019-05-26 12:06:12.508 !MESSAGE FrameworkEvent ERROR !STACK 0 java.lang.NoClassDefFoundError: javax/annotation/PreDestroy at org.eclipse.e4.core.internal.di.InjectorImpl.disposed(InjectorImpl.java:426) at org.eclipse.e4.core.internal.di.Requestor.disposed(Requestor.java:154) at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:78) at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:111) at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.handleInvalid(TrackableComputationExt.java:74) at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:176) at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.dispose(EclipseContextOSGi.java:106) at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.bundleChanged(EclipseContextOSGi.java:139) at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:903) at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:156) at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) at org.eclipse.osgi.container.Module.doStop(Module.java:634) at org.eclipse.osgi.container.Module.stop(Module.java:498) at org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:202) at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule$1.run(EquinoxBundle.java:165) at java.base/java.lang.Thread.run(Thread.java:844) Caused by: java.lang.ClassNotFoundException: javax.annotation.PreDestroy cannot be found by org.eclipse.e4.core.di_1.6.1.v20160712-0927 at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:410) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:372) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:364) at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:161) at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:499) ... 21 more
Hi Sergey,
Thanks for the bug report; I will pass on to the engineering team to see if they have any ideas. What specific version of macOS are you running?
Cheers, Pete
Hi, Peter
My macOS version : Mojave 10.14.5 (mac mini 2012)
We are happy to provide any additional information you need.
Thanks for the information; we've had this working on at least one Mojave-based machine internally so this is a new issue we've not seen before.
We have a new release due out soon (this week hopefully), which will switch the macOS installation to use a signed .dmg disk image, which should avoid issues caused by the application translocation randomizing paths. At this point it's probably sensible to wait for that, given it's due out in the very near future.
In the interim, our engineering team noted that you are using a JDK10 install for the custom JDK you are providing, which is likely to be to new (we ship with a JDK8 build).
*EDIT* On a clean OS X 10.9.5 machine (no spctl has been run there), the following works for us:
$ which java /usr/bin/java $ /usr/bin/java -version <... 1.8.0_66-b17 ... in my case> $ cd /Users/<user>/Downloads/mobilestudio-macosx/graphics_analyzer/ $ graphics_analyzer/gui/Graphics\ Analyzer.app/Contents/MacOS/aga -vm /usr/bin
Cheers,Pete
Thank you, I understand, I will wait for the new version
I did what you wrote above - again it did not start, and here is a log. In any case, I will wait for the update =))
!SESSION 2019-04-20 15:23:18.257 ----------------------------------------------- eclipse.buildId=unknown java.version=1.8.0_60 java.vendor=Oracle Corporation BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_US Framework arguments: -keyring /Users/sergeiloskutnikov/.eclipse_keyring Command-line arguments: -os macosx -ws cocoa -arch x86_64 -data @user.home/.aga_workspace_5.2.0 -keyring /Users/sergeiloskutnikov/.eclipse_keyring !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-04-20 15:23:22.428 !MESSAGE Unable to acquire PluginConverter service during generation for: /private/var/folders/f1/f5b0cbrn3kz08pw4sh_l64h40000gn/T/AppTranslocation/63B0A678-8588-401B-A6B3-C364AA629710/d/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar. !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-04-20 15:23:22.466 !MESSAGE Unable to acquire PluginConverter service during generation for: /private/var/folders/f1/f5b0cbrn3kz08pw4sh_l64h40000gn/T/AppTranslocation/63B0A678-8588-401B-A6B3-C364AA629710/d/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar. !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-04-20 15:23:22.497 !MESSAGE Unable to acquire PluginConverter service during generation for: /private/var/folders/f1/f5b0cbrn3kz08pw4sh_l64h40000gn/T/AppTranslocation/63B0A678-8588-401B-A6B3-C364AA629710/d/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar. !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-04-20 15:23:22.523 !MESSAGE Unable to acquire PluginConverter service during generation for: /private/var/folders/f1/f5b0cbrn3kz08pw4sh_l64h40000gn/T/AppTranslocation/63B0A678-8588-401B-A6B3-C364AA629710/d/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar. !SESSION 2019-05-26 10:55:00.500 ----------------------------------------------- eclipse.buildId=unknown java.version=10 java.vendor=Oracle Corporation BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_RU Framework arguments: -keyring /Users/sergeiloskutnikov/.eclipse_keyring Command-line arguments: -os macosx -ws cocoa -arch x86_64 -data @user.home/.aga_workspace_5.2.0 -keyring /Users/sergeiloskutnikov/.eclipse_keyring !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 10:55:05.511 !MESSAGE Unable to acquire PluginConverter service during generation for: /private/var/folders/f1/f5b0cbrn3kz08pw4sh_l64h40000gn/T/AppTranslocation/CA444C30-D5EA-4457-B5E8-6DD8F41236E2/d/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar. !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 10:55:05.571 !MESSAGE Unable to acquire PluginConverter service during generation for: /private/var/folders/f1/f5b0cbrn3kz08pw4sh_l64h40000gn/T/AppTranslocation/CA444C30-D5EA-4457-B5E8-6DD8F41236E2/d/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar. !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 10:55:05.604 !MESSAGE Unable to acquire PluginConverter service during generation for: /private/var/folders/f1/f5b0cbrn3kz08pw4sh_l64h40000gn/T/AppTranslocation/CA444C30-D5EA-4457-B5E8-6DD8F41236E2/d/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar. !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 10:55:05.634 !MESSAGE Unable to acquire PluginConverter service during generation for: /private/var/folders/f1/f5b0cbrn3kz08pw4sh_l64h40000gn/T/AppTranslocation/CA444C30-D5EA-4457-B5E8-6DD8F41236E2/d/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar. !ENTRY org.eclipse.osgi 4 0 2019-05-26 10:55:06.860 !MESSAGE Application error !STACK 1 org.eclipse.e4.core.di.InjectionException: java.lang.NoClassDefFoundError: javax/annotation/PostConstruct at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:386) at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:294) at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162) at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultHeadlessContext(E4Application.java:490) at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultContext(E4Application.java:504) at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:203) at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:632) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:336) at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:610) at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:148) at com.arm.mgd.ui.Application.start(Application.java:112) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.base/java.lang.reflect.Method.invoke(Method.java:564) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610) at org.eclipse.equinox.launcher.Main.run(Main.java:1519) Caused by: java.lang.NoClassDefFoundError: javax/annotation/PostConstruct at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:151) at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:375) ... 22 more Caused by: java.lang.ClassNotFoundException: javax.annotation.PostConstruct cannot be found by org.eclipse.e4.core.di_1.6.1.v20160712-0927 at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:410) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:372) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:364) at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:161) at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:499) ... 24 more !ENTRY org.eclipse.e4.ui.workbench 4 0 2019-05-26 10:55:06.870 !MESSAGE FrameworkEvent ERROR !STACK 0 java.lang.NoClassDefFoundError: javax/annotation/PreDestroy at org.eclipse.e4.core.internal.di.InjectorImpl.disposed(InjectorImpl.java:426) at org.eclipse.e4.core.internal.di.Requestor.disposed(Requestor.java:154) at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:78) at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:111) at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.handleInvalid(TrackableComputationExt.java:74) at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:176) at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.dispose(EclipseContextOSGi.java:106) at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.bundleChanged(EclipseContextOSGi.java:139) at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:903) at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:156) at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) at org.eclipse.osgi.container.Module.doStop(Module.java:634) at org.eclipse.osgi.container.Module.stop(Module.java:498) at org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:202) at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule$1.run(EquinoxBundle.java:165) at java.base/java.lang.Thread.run(Thread.java:844) Caused by: java.lang.ClassNotFoundException: javax.annotation.PreDestroy cannot be found by org.eclipse.e4.core.di_1.6.1.v20160712-0927 at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:410) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:372) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:364) at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:161) at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:499) ... 21 more !SESSION 2019-05-26 11:00:37.083 ----------------------------------------------- eclipse.buildId=unknown java.version=10 java.vendor=Oracle Corporation BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_RU Framework arguments: -keyring /Users/sergeiloskutnikov/.eclipse_keyring Command-line arguments: -os macosx -ws cocoa -arch x86_64 -data @user.home/.aga_workspace_5.2.0 -keyring /Users/sergeiloskutnikov/.eclipse_keyring !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 11:00:40.651 !MESSAGE Unable to acquire PluginConverter service during generation for: /private/var/folders/f1/f5b0cbrn3kz08pw4sh_l64h40000gn/T/AppTranslocation/D92FA5A1-9F04-41BC-A58F-D34FC610A58B/d/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar. !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 11:00:40.695 !MESSAGE Unable to acquire PluginConverter service during generation for: /private/var/folders/f1/f5b0cbrn3kz08pw4sh_l64h40000gn/T/AppTranslocation/D92FA5A1-9F04-41BC-A58F-D34FC610A58B/d/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar. !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 11:00:40.735 !MESSAGE Unable to acquire PluginConverter service during generation for: /private/var/folders/f1/f5b0cbrn3kz08pw4sh_l64h40000gn/T/AppTranslocation/D92FA5A1-9F04-41BC-A58F-D34FC610A58B/d/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar. !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 11:00:40.762 !MESSAGE Unable to acquire PluginConverter service during generation for: /private/var/folders/f1/f5b0cbrn3kz08pw4sh_l64h40000gn/T/AppTranslocation/D92FA5A1-9F04-41BC-A58F-D34FC610A58B/d/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar. !ENTRY org.eclipse.osgi 4 0 2019-05-26 11:00:41.766 !MESSAGE Application error !STACK 1 org.eclipse.e4.core.di.InjectionException: java.lang.NoClassDefFoundError: javax/annotation/PostConstruct at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:386) at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:294) at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162) at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultHeadlessContext(E4Application.java:490) at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultContext(E4Application.java:504) at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:203) at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:632) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:336) at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:610) at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:148) at com.arm.mgd.ui.Application.start(Application.java:112) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.base/java.lang.reflect.Method.invoke(Method.java:564) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610) at org.eclipse.equinox.launcher.Main.run(Main.java:1519) Caused by: java.lang.NoClassDefFoundError: javax/annotation/PostConstruct at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:151) at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:375) ... 22 more Caused by: java.lang.ClassNotFoundException: javax.annotation.PostConstruct cannot be found by org.eclipse.e4.core.di_1.6.1.v20160712-0927 at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:410) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:372) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:364) at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:161) at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:499) ... 24 more !ENTRY org.eclipse.e4.ui.workbench 4 0 2019-05-26 11:00:41.776 !MESSAGE FrameworkEvent ERROR !STACK 0 java.lang.NoClassDefFoundError: javax/annotation/PreDestroy at org.eclipse.e4.core.internal.di.InjectorImpl.disposed(InjectorImpl.java:426) at org.eclipse.e4.core.internal.di.Requestor.disposed(Requestor.java:154) at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:78) at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:111) at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.handleInvalid(TrackableComputationExt.java:74) at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:176) at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.dispose(EclipseContextOSGi.java:106) at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.bundleChanged(EclipseContextOSGi.java:139) at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:903) at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:156) at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) at org.eclipse.osgi.container.Module.doStop(Module.java:634) at org.eclipse.osgi.container.Module.stop(Module.java:498) at org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:202) at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule$1.run(EquinoxBundle.java:165) at java.base/java.lang.Thread.run(Thread.java:844) Caused by: java.lang.ClassNotFoundException: javax.annotation.PreDestroy cannot be found by org.eclipse.e4.core.di_1.6.1.v20160712-0927 at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:410) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:372) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:364) at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:161) at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:499) ... 21 more !SESSION 2019-05-26 11:06:58.701 ----------------------------------------------- eclipse.buildId=unknown java.version=10 java.vendor=Oracle Corporation BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_RU Framework arguments: -keyring /Users/sergeiloskutnikov/.eclipse_keyring Command-line arguments: -os macosx -ws cocoa -arch x86_64 -data @user.home/.aga_workspace_5.2.0 -keyring /Users/sergeiloskutnikov/.eclipse_keyring !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 11:07:02.216 !MESSAGE Unable to acquire PluginConverter service during generation for: /private/var/folders/f1/f5b0cbrn3kz08pw4sh_l64h40000gn/T/AppTranslocation/D6390C76-0C01-4A0E-9556-003A9CF51F84/d/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar. !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 11:07:02.271 !MESSAGE Unable to acquire PluginConverter service during generation for: /private/var/folders/f1/f5b0cbrn3kz08pw4sh_l64h40000gn/T/AppTranslocation/D6390C76-0C01-4A0E-9556-003A9CF51F84/d/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar. !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 11:07:02.305 !MESSAGE Unable to acquire PluginConverter service during generation for: /private/var/folders/f1/f5b0cbrn3kz08pw4sh_l64h40000gn/T/AppTranslocation/D6390C76-0C01-4A0E-9556-003A9CF51F84/d/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar. !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 11:07:02.338 !MESSAGE Unable to acquire PluginConverter service during generation for: /private/var/folders/f1/f5b0cbrn3kz08pw4sh_l64h40000gn/T/AppTranslocation/D6390C76-0C01-4A0E-9556-003A9CF51F84/d/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar. !ENTRY org.eclipse.osgi 4 0 2019-05-26 11:07:03.357 !MESSAGE Application error !STACK 1 org.eclipse.e4.core.di.InjectionException: java.lang.NoClassDefFoundError: javax/annotation/PostConstruct at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:386) at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:294) at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162) at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultHeadlessContext(E4Application.java:490) at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultContext(E4Application.java:504) at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:203) at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:632) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:336) at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:610) at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:148) at com.arm.mgd.ui.Application.start(Application.java:112) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.base/java.lang.reflect.Method.invoke(Method.java:564) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610) at org.eclipse.equinox.launcher.Main.run(Main.java:1519) Caused by: java.lang.NoClassDefFoundError: javax/annotation/PostConstruct at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:151) at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:375) ... 22 more Caused by: java.lang.ClassNotFoundException: javax.annotation.PostConstruct cannot be found by org.eclipse.e4.core.di_1.6.1.v20160712-0927 at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:410) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:372) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:364) at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:161) at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:499) ... 24 more !ENTRY org.eclipse.e4.ui.workbench 4 0 2019-05-26 11:07:03.366 !MESSAGE FrameworkEvent ERROR !STACK 0 java.lang.NoClassDefFoundError: javax/annotation/PreDestroy at org.eclipse.e4.core.internal.di.InjectorImpl.disposed(InjectorImpl.java:426) at org.eclipse.e4.core.internal.di.Requestor.disposed(Requestor.java:154) at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:78) at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:111) at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.handleInvalid(TrackableComputationExt.java:74) at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:176) at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.dispose(EclipseContextOSGi.java:106) at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.bundleChanged(EclipseContextOSGi.java:139) at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:903) at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:156) at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) at org.eclipse.osgi.container.Module.doStop(Module.java:634) at org.eclipse.osgi.container.Module.stop(Module.java:498) at org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:202) at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule$1.run(EquinoxBundle.java:165) at java.base/java.lang.Thread.run(Thread.java:844) Caused by: java.lang.ClassNotFoundException: javax.annotation.PreDestroy cannot be found by org.eclipse.e4.core.di_1.6.1.v20160712-0927 at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:410) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:372) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:364) at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:161) at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:499) ... 21 more !SESSION 2019-05-26 12:06:06.122 ----------------------------------------------- eclipse.buildId=unknown java.version=10 java.vendor=Oracle Corporation BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_RU Framework arguments: -keyring /Users/sergeiloskutnikov/.eclipse_keyring Command-line arguments: -os macosx -ws cocoa -arch x86_64 -data @user.home/.aga_workspace_5.2.0 -keyring /Users/sergeiloskutnikov/.eclipse_keyring !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 12:06:11.253 !MESSAGE Unable to acquire PluginConverter service during generation for: /private/var/folders/f1/f5b0cbrn3kz08pw4sh_l64h40000gn/T/AppTranslocation/1C516BFA-22F7-45AC-B18C-70CDFAE9524B/d/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar. !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 12:06:11.297 !MESSAGE Unable to acquire PluginConverter service during generation for: /private/var/folders/f1/f5b0cbrn3kz08pw4sh_l64h40000gn/T/AppTranslocation/1C516BFA-22F7-45AC-B18C-70CDFAE9524B/d/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar. !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 12:06:11.332 !MESSAGE Unable to acquire PluginConverter service during generation for: /private/var/folders/f1/f5b0cbrn3kz08pw4sh_l64h40000gn/T/AppTranslocation/1C516BFA-22F7-45AC-B18C-70CDFAE9524B/d/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar. !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 12:06:11.361 !MESSAGE Unable to acquire PluginConverter service during generation for: /private/var/folders/f1/f5b0cbrn3kz08pw4sh_l64h40000gn/T/AppTranslocation/1C516BFA-22F7-45AC-B18C-70CDFAE9524B/d/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar. !ENTRY org.eclipse.osgi 4 0 2019-05-26 12:06:12.493 !MESSAGE Application error !STACK 1 org.eclipse.e4.core.di.InjectionException: java.lang.NoClassDefFoundError: javax/annotation/PostConstruct at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:386) at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:294) at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162) at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultHeadlessContext(E4Application.java:490) at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultContext(E4Application.java:504) at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:203) at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:632) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:336) at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:610) at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:148) at com.arm.mgd.ui.Application.start(Application.java:112) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.base/java.lang.reflect.Method.invoke(Method.java:564) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610) at org.eclipse.equinox.launcher.Main.run(Main.java:1519) Caused by: java.lang.NoClassDefFoundError: javax/annotation/PostConstruct at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:151) at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:375) ... 22 more Caused by: java.lang.ClassNotFoundException: javax.annotation.PostConstruct cannot be found by org.eclipse.e4.core.di_1.6.1.v20160712-0927 at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:410) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:372) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:364) at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:161) at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:499) ... 24 more !ENTRY org.eclipse.e4.ui.workbench 4 0 2019-05-26 12:06:12.508 !MESSAGE FrameworkEvent ERROR !STACK 0 java.lang.NoClassDefFoundError: javax/annotation/PreDestroy at org.eclipse.e4.core.internal.di.InjectorImpl.disposed(InjectorImpl.java:426) at org.eclipse.e4.core.internal.di.Requestor.disposed(Requestor.java:154) at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:78) at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:111) at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.handleInvalid(TrackableComputationExt.java:74) at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:176) at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.dispose(EclipseContextOSGi.java:106) at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.bundleChanged(EclipseContextOSGi.java:139) at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:903) at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:156) at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) at org.eclipse.osgi.container.Module.doStop(Module.java:634) at org.eclipse.osgi.container.Module.stop(Module.java:498) at org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:202) at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule$1.run(EquinoxBundle.java:165) at java.base/java.lang.Thread.run(Thread.java:844) Caused by: java.lang.ClassNotFoundException: javax.annotation.PreDestroy cannot be found by org.eclipse.e4.core.di_1.6.1.v20160712-0927 at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:410) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:372) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:364) at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:161) at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:499) ... 21 more !SESSION 2019-05-28 15:57:03.633 ----------------------------------------------- eclipse.buildId=unknown java.version=10 java.vendor=Oracle Corporation BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_RU Command-line arguments: -os macosx -ws cocoa -arch x86_64 -data @user.home/.aga_workspace_5.2.0 !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-28 15:57:08.743 !MESSAGE Unable to acquire PluginConverter service during generation for: /Users/sergeiloskutnikov/Downloads/DSHVE-BN-00005-r19p0-23rel0/mobilestudio-macosx/graphics_analyzer/gui/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar. !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-28 15:57:08.817 !MESSAGE Unable to acquire PluginConverter service during generation for: /Users/sergeiloskutnikov/Downloads/DSHVE-BN-00005-r19p0-23rel0/mobilestudio-macosx/graphics_analyzer/gui/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar. !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-28 15:57:08.874 !MESSAGE Unable to acquire PluginConverter service during generation for: /Users/sergeiloskutnikov/Downloads/DSHVE-BN-00005-r19p0-23rel0/mobilestudio-macosx/graphics_analyzer/gui/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar. !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-28 15:57:08.917 !MESSAGE Unable to acquire PluginConverter service during generation for: /Users/sergeiloskutnikov/Downloads/DSHVE-BN-00005-r19p0-23rel0/mobilestudio-macosx/graphics_analyzer/gui/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar. !ENTRY org.eclipse.osgi 4 0 2019-05-28 15:57:10.250 !MESSAGE Application error !STACK 1 org.eclipse.e4.core.di.InjectionException: java.lang.NoClassDefFoundError: javax/annotation/PostConstruct at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:386) at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:294) at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162) at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultHeadlessContext(E4Application.java:490) at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultContext(E4Application.java:504) at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:203) at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:632) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:336) at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:610) at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:148) at com.arm.mgd.ui.Application.start(Application.java:112) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.base/java.lang.reflect.Method.invoke(Method.java:564) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610) at org.eclipse.equinox.launcher.Main.run(Main.java:1519) Caused by: java.lang.NoClassDefFoundError: javax/annotation/PostConstruct at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:151) at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:375) ... 22 more Caused by: java.lang.ClassNotFoundException: javax.annotation.PostConstruct cannot be found by org.eclipse.e4.core.di_1.6.1.v20160712-0927 at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:410) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:372) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:364) at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:161) at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:499) ... 24 more !ENTRY org.eclipse.e4.ui.workbench 4 0 2019-05-28 15:57:10.261 !MESSAGE FrameworkEvent ERROR !STACK 0 java.lang.NoClassDefFoundError: javax/annotation/PreDestroy at org.eclipse.e4.core.internal.di.InjectorImpl.disposed(InjectorImpl.java:426) at org.eclipse.e4.core.internal.di.Requestor.disposed(Requestor.java:154) at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:78) at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:111) at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.handleInvalid(TrackableComputationExt.java:74) at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:176) at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.dispose(EclipseContextOSGi.java:106) at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.bundleChanged(EclipseContextOSGi.java:139) at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:903) at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:156) at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) at org.eclipse.osgi.container.Module.doStop(Module.java:634) at org.eclipse.osgi.container.Module.stop(Module.java:498) at org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:202) at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule$1.run(EquinoxBundle.java:165) at java.base/java.lang.Thread.run(Thread.java:844) Caused by: java.lang.ClassNotFoundException: javax.annotation.PreDestroy cannot be found by org.eclipse.e4.core.di_1.6.1.v20160712-0927 at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:410) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:372) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:364) at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:161) at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:499) ... 21 more
That log still seems to be picking up "java.version=10", which is too new and known to cause problems (both Java 9 and 10 have dropped support for classes the version of eclipse we use rely upon). The soon-to-be-released version will use the pre-packaged JVM, so we think that should solve it.
Ok, I understand. I will wait for the new version.thanks for your help
Hi Sergey, Mobile Studio 2019.1, with new the macOS installer, is now available for download:https://developer.arm.com/tools-and-software/graphics-and-gaming/arm-mobile-studio/downloads
Let us know if you have any problems,
Hi Peter, yes, everything starts and works. Now I will already try how it will work with devices. Many thanks for your help !
