Bitstream file download failure in MPS3
Hi Staff,
I am facing the problem on downloading step of the bit stream file in MPS3 board.
Below error messages are being printed.
Powering up system...
Switching on main power...
Configuring motherboard (rev C, var A)...
Reading Board File \MB\HBI0309C\AN524\an524_v1.txt
Configuring FPGA from file \MB\HBI0309C\AN524\524_t_1.bit
Address: 0x015E0000
ERROR: FPGA did not configure.
Failed to program FPGA...
Powering down...
Board powered down, use REBOOT to restart.
Can you please guide me to resolve this error?
Thank you
  • As a test, can you download and try to install AN533 to the board:
    https://developer.arm.com/downloads/view/AN533
    If that works OK, but AN524 does not, then I believe the issue is due to the on-board battery expiring.
    Please contact your point of purchase as the board will need to be repaired.
    If you purchased directly from Arm, please raise a support case from the menu below.
  • Hi Ronan,
    Thank you for the advice.
    As per your instructions I tried AN533 and it worked. See the logs below:
    Cmd> reboot
    Rebooting...
    Disabling debug USB..
    Board rebooting...
    ARM V2M-MPS3 Firmware v1.4.1
    Build Date: Apr 28 2020
    Reading Board File \MB\HBI0309C\Blinky\blinky.txt
    Configuring FPGA from file \MB\HBI0309C\Blinky\blinky.bit
    Address: 0x00660000
    FPGA configuration complete.
    OSCCLK0 : 24.000000MHz
    OSCCLK1 : 32.000000MHz
    OSCCLK2 : 50.000000MHz
    OSCCLK3 : 50.000000MHz
    OSCCLK4 : 24.576000MHz
    OSCCLK5 : 23.750000MHz
    OSCCLK setup: PASSED
    GTXCLK (100): PASSED
    FPGA does not support MCC<>SCC interface
    FPGA does not support MCC<>SMB interface
    UART0: MCC, UART1: FPGA0
    Releasing CB_nRST
    Enabling debug USB.
    USB Serial Number = 5005437700080
    After that I tried AN524 and it failed on FPGA configuration state. See the logs below.
    Cmd>
    ARM V2M-MPS3 Boot loader v1.0.0
    HBI0309 build 1044
    Cmd>
    Programming Boot FLASH from \MB\HBI0309C\mbb_v224.ebf
    Device programmed: 40%
    Boot FLASH updated.
    Powering down...
    Resetting board.
    HBI0309 build 4628
    MBbios update in progress DO NOT SWITCH OFF...
    MBbios update complete.
    ARM V2M-MPS3 Firmware v2.2.4
    Build Date: Nov 28 2023
    Creating MCC_HELP.TXT
    Reading Board File \MB\HBI0309C\AN524\an524_v3.txt
    Configuring FPGA from file \MB\HBI0309C\AN524\524_t_3.bit
    Address: 0x014A0000
    Powering down...
    Cmd> reboot
    Address: 0x014A0000
    Powering down...
    Cmd>
    So as you suggested we will contact the point of purchase.
    Thank you
  • Hi Ronan,
    I have an additional question.
    When I connect the MPS3 board using the debug USB cable, the V2M_MPS3 drive does not appear on my system.
    Do you have any suggestions for resolving this issue?
    This board has been in use for several months without any problems, and we have not encountered this behavior before. However, we are now unable to use the board, and flashing the FPGA file is also failing.
    Thank you and expecting your advice on this.
  • Can you remove the micro SD Card (this contains the V2M_MPS3) file system, and (re)write it directly from your PC?
    I suspect something has been corrupted there.
    For the FPGA not configuring error - this will need to be manually repaired.
  • Hi Ronan,
    Thank you for that advice related to SD card. I tried to format it and now it is showing up in the file system as expected.
    As I informed earlier now I am in the process of contacting point of purchase for repairing the board.
