I'm trying to connect via ssh to a Buildroot Linux instance running in an Armv-A Base RevC AEM FVP. These are the parameters I'm using:
FVP_Base_RevC-2xAEMvA \ -C bp.smsc_91c111.enabled=true -C bp.hostbridge.userNetworking=true \ -C bp.hostbridge.userNetPorts=127.0.0.1:8022=22 -C bp.hostbridge.userNetSubnet=10.0.2.0/23 \ ....
Then I try to connect by running `ssh root@localhost -p 8022`, but the command just hangs.
Foundation_Platform \ --network=nat \ --network-nat-subnet=10.0.2.0/23 \ --network-nat-ports=127.0.0.1:8022=22 \ ....
