Arm Compiler for Embedded 6.19: sizeof(array) does not match actual stack storage when the element type is an aligned typedef — silent buffer overrun
### Reproducer
typedef __attribute__((aligned(4))) uint8_t uint8_aligned_t;
static uint8_t test_sizeof(void)
    uint8_t a = 0x42;
    uint8_aligned_t x[5];
    uint8_t b = 0x41;
    for (uint8_t i = 0; i < sizeof(x); i++)
        x[i] = i;
    return a + b;
### Observation
sizeof(uint8_aligned_t) == 1
sizeof(x) == 8
However, only 5 bytes are reserved on the stack for x. The actual stack layout produced by the compiler is:
b | x[0..4] | pad | pad | a
The loop runs 8 iterations; the extra writes overwrite the padding bytes and a.
### Questions
- Why does sizeof(x) evaluate to 8 when sizeof(uint8_aligned_t) is 1 and the array has 5 elements?
- Why does armclang reserve only 5 bytes of stack for x while simultaneously reporting sizeof(x) == 8?
  The two values disagree, and the trailing 3 bytes overlap an unrelated live local (a), so any sizeof(x)-driven loop silently corrupts memory
### Note
Aligning the array variable instead of the element typedef behaves consistently (sizeof(x) == 5, alignment 4, no overrun):
uint8_t x[5] __attribute__((aligned(4)));
