Where Can I post a bug about the arm non eabi compiler?
kind regards,
Nikos
Assuming this is GCC, I would post on the upstream bug tracker: https://gcc.gnu.org/bugs/
Cheers, Pete
Hi, thank you for your reply, I posted it before a month but they said, this is an ARM bug and not a gcc.
gcc.gnu.org/.../show_bug.cgi
I also posted a question in Centos 9 Forum and they said that the librarys are old and not anymore available in the distro.
Hi Nikos,
There is a workaround available here - https://stackoverflow.com/questions/73525776/install-ncurses-5-in-centos-9
We'll have a fix for this issue in the next release.
Hi, when is coming the new release? There is also some other libs not only ncurses, did you fix it also?
