Hello to all,
I am trying to port the old arm project written in C language and partly in assembly that was compiled with the armcc version 4.1. And I must mention I am not an expert on this, still learning, reading the arm documentation.
The selected new compiler is armclang v6.16. For the assembly code I am still using the armasm.
I have read the migration document and the difference between the old arm v5 and new arm v6 compiler and adapted the compiler/linker flags accordingly.
Everything is ok with the build, but the linking is failing with the error:
Error: L6291E: Cannot assign Fixed Execution Region ... Load Address:0x000179b4. Load Address must be greater than or equal to next available Load Address:0x00017f7c.
and what I could see from the map file, using fromelf for specific object file is that the build output from the armclang is bigger than when I used the older compiler. I did some basic test to compile empty functions and found out the following:
- Using old compiler: building the empty function void and non-void creates function of size 2 bytes when I look in the object file using fromelf or in the map file (Memory map of the image)
- Using the new compiler:
- building the empty function void creates function size of 2 bytes
- building the empty non void function creates function size of 4 bytes. (Very strange why additional 2 bytes).
For the code optimization I am using flag -oz as we are not using LTO in the project.
For the moment I am still trying to find out the reason, also checking if I misses any specific compiler flags.
Thank you for any useful information that could help me solve this mystery, Iknerf
Hi Frenk
This is probably beyond the scope of what I can provide here - we would likely need reproducible examples to advise further.
Can you raise an official support case from the support menu above?
At the moment the armlink alignment is solved by using the deprecated flag --legacyalign and change in the scatter file: ER_FLASH_LIB AlignExpr(+0, 4) FIXED
Best regards, Iknerf
I solved the problem by using the deprecated armlink flag --legacyalign and adapting the line in the scatter file: ER_FLASH_LIB AlignExpr(+0, 4) FIXED :-)Now build is failing as there I have some old embedded assembly functions defined as __asm and using PRESERVE8, ... So I need to check if armclang has some flag to support the old syntax so that I dont have to change everything.
I solved the positioning problem by passing deprecated flag --legacyalign to the armlink and change the line in scatter file to the :ER_FLASH_LIB AlignExpr(+0, 4) FIXED
Now I am getting syntax errors for embedded assembly functions in the C. Like __asm is not recognized, PRESERVE8 invalid. So I hope there is a flag I can use that armclang will support old syntax as otherwise I would need to correct all the embedded assembly functions :(
VERY STRANGE, Lot of my replies are gone. What is happening to the forum?
This is the last reply I had saved.
Hey just to answer the first question. One of our moderation tools looks for repetitive text within content as a spam prevention tool. Sometimes this means content with code blocks gets flagged.
I have approved the post if you want to keep it in this thread.
Oli
Arm Community Manager
Hello Oliver,
Thank you very much for information and very quick response
Yes keep it in thread, Iknerf
I don't think there is more we can suggest here. The underlying optimizers behave quite differently.
