Hello
I am a new member and I have just registered and starting to learn ARM.I have a project that I need a legacy ARM compiler for it - to be exact I want to install the Arm Compiler 5.06 u6 Build 750 Since it had been tested and approved for many OS
I tried downloading the ARM and I was NOT able to get anything at all.After clicking the + (PLUS) symbol on the ARM that I want to download and clicked the Windows 32bit Button - I was transferred to the homepage of ARM
I was NOT able to download - basically I expect to get a fuile when I click a download button - BUT I was not getting anything.I would be happy if you can assist with that download and that i will be able to continue my learning of ARM development.
Aryeduino
Same here. I'm trying to download Arm Compiler 5.06 update 7 (build 960) here https://developer.arm.com/downloads/-/legacy-compilers#arm-compiler-5But it just brings me to the doownloads home page.
Same here. I'm trying to download Arm Compiler 5.06 update 6 (build 750)
I have checked with a colleague. This temporary problem is known, and we are working on a solution however we do not have a current timeframe for a fix. We apologize for the inconvenience. We will provide an update as soon as we have one.
Oli
Oliver,Thank you for the update. Can Arm Compiler 5.06 update 7(build 960) be made available for my use through a different method? Maybe a TFTP link. This issue is now impacting my company's progress on a critical issue. Please advise.
Andrew
Hello, why I can't download the legacy version of Arm Compiler 5.06 update 7 (build 960)?
I would advise you contact Arm Support if you need urgent help with this issue.
Hello MJCoder
As stated above, there is known that we are working to resolve. An update will be provided as soon as possible. Thank you for your patience while we resolve this matter.
Hello all,
Apologies for the ongoing issues you have experienced.
Please follow the link for your required compiler from here:https://developer.arm.com/documentation/ka005184
For more information, including instructions on how to use the Product Download Hub interface, see:https://developer.arm.com/documentation/ka005198
Regards
Ronan
The link for the legacy compiler brings me to the login page again.
Still facing the same issue with downloading Arm Compiler 5.06 update 7 (build 960).
This is expected - you must login to download the update.
Hi, I have the same problem here, the login page is reached, then the link to download AC5 returns to the login page again.
Same goes for me!!! Can anyone help. If I login again then I am not never never apporaching the site for file:///C:/Users/Ich/Desktop/Legacy%20Arm%20Compiler%205,%204.1,%20and%20RVCT%20(ACOMP5).html !!!! After 2 days full tries I cann not help this any more.......................
Hey COMMUNITY I found the PAAAATHHH!!!!!
I finally installed the very annoying four-King, Keil Compiler Version 5 NOWW!!!
It is, when you are again directed to the login Site, just login and you see the start site.
1. If you are logged in and in Start Site, go for Home->Downloads->search.
2. In Search window you just write the version of compiler you are longing for like e.g Legacy Arm Compiler 5, 4.1, and RVCT (ACOMP5). You have to type precisely though.
3. Click on the link in your search result and !! THen you are directed to download. It looks exactly the same as you did it before, but please do it again, even if it jsut looks dummy
like doing things twice. It has a good reasin! Choose the Arm Cortex Compiler Index and, also, one of windows or linus version to install.
4. You finally have your real working SETUP in your Zip data for your hard earned Compiler Version 5.
I am just now angry and happy after 2 days and nights efforts to jsut find the bug.
Happy new year!
Hello, the link to the download is in the table at:https://developer.arm.com/documentation/ka005184/latest/
From there, you can select the specific version from the pull-down.
