I am trying to update the tool-chain for a bare metal embedded project. We are building on windows an up to now we have been using version 5.4.1 20160609 (release) [ARM/embedded-5-branch revision 237715].
Now I am trying version 9.3.1 20200408 (release) (9-2020-q2-update), but I have an issue with an undefined symbol while linking: __sync_synchronize isreported as missing and I have no idea from which source this symbol should be resolved. Do I have to link a library that I am missing? Should I give differentflags to the compiler so that it generates the code for that function?
Below is a sample that compiles and links just fine with the old tool-chain, but fails with the new one. In both cases this command line was used:
arm-none-eabi-g++ -mthumb -specs=nosys.specs sample.cpp
The exact failure message is:c:/projects/cpt_tools/gcc-arm-none-eabi/9.3.1/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/bin/ld.exe: C:\Users\RMatano\AppData\Local\Temp\ccSZkMXN.o: in function `use_static_inst(int)':synch.cpp:(.text+0xc): undefined reference to `__sync_synchronize'collect2.exe: error: ld returned 1 exit status
Here is the content of sample.cpp:
// compile with 'arm-none-eabi-g++.exe -mthumb -specs=nosys.specs sample.cpp'//// result: in function `use_static_inst(int)':// synch.cpp:(.text+0x18): undefined reference to `__sync_synchronize'
class A{ int m_i;
class A
int m_i;
public:
A(int i) : m_i(i) { }
A(int i) : m_i(i)
int value(int x) { return m_i + x; }};
int value(int x)
return m_i + x;
int use_static_inst(int x){ // for this ctor the compiler generates a call to __sync_synchronize static A a(0);
static A a(0);
return a.value(x);}
return a.value(x);
int main(int argc, char* argv[]){ return use_static_inst(argc);}
BTW: There is no difference when I run my test on Linux:
rmatano@GERD1330-devbox:~/gcc-arm-none-eabi-9-2020-q2-update/bin$ ./arm-none-eabi-g++ -mthumb -specs=nosys.specs sample.cpp/media/persistent_storage/home/rmatano/gcc-arm-none-eabi-9-2020-q2-update/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/bin/ld: /tmp/ccltslyj.o: in function `use_static_inst(int)': />sample.cpp:(.text+0xc): undefined reference to `__sync_synchronize' collect2: error: ld returned 1 exit status
