Hello!
I use arm-none-eabi to compile my STM32 project. I want to link my project files to an archive, e.g. libexample.a, to allow link with other objects, e.g. example.o. The libexample.a contains weak symbol replaced by example.o and example.o uses functions from libexample.a.
Now I face the following problem: When I create libexample.a and then link libexample.a with example.o, the resulting elf/bin is malfunction.
When I take example.o and link it directly with .o files used to crate libexample.a, the resulting elf/bin is OK.
Compile flags are equal.
The further investigation showed, that:
The Makefile snippet is below:
libexample.a: $(OBJS) @echo Creating static library $@ $(AR) rcs $@ $(OBJS) ofiles: @echo Compiling @arm-none-eabi-gcc -c $(CFLAGS) $(INCLUDE) example.c -o example.o @echo "Linking (creating .elf)" @arm-none-eabi-gcc $(OBJS) example.o $(LDFLAGS) -o example.elf @echo "Creating .hex file" @arm-none-eabi-objcopy -O ihex example.elf example.hex @echo "Creating .bin file" @arm-none-eabi-objcopy -O binary -S example.elf example.bin afile: libexample.a @echo Compiling @arm-none-eabi-gcc -c $(CFLAGS) $(INCLUDE) example.c -o example.o @echo "Linking (creating .elf)" @arm-none-eabi-gcc -L. -lexample example.o $(LDFLAGS) -o example2.elf @echo "Creating .hex file" @arm-none-eabi-objcopy -O ihex example2.elf example2.hex @echo "Creating .bin file" @arm-none-eabi-objcopy -O binary -S example2.elf example2.bin
example.bin size is 172Kexample2.bin size is 144K
