Site
Search
User
Site
Search
User
Support forums
Arm Development Studio forum
How to avoid literal pools ?
Jump...
Cancel
Locked
Locked
Replies
Subscribers
118 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Christophe Beausoleil
over 12 years ago
Note: This was originally posted on 19th January 2012 at
http://forums.arm.com
Hello everyone,
I am using Cortex-R4F (TI TMS570), and I noticed that ARM C compiler often adds data in literal pools as in example below :
C code
RTI_Re_TickFlag = 0;
ASM generated code :
000004 4c66 LDR r4,|L1.416|
000006 2700 MOVS r7,#0
ENDP
|L1.416|
DCD RTI_Re_TickFlag
My problem is that this constant is in the same section than the code, so the Cortex-R4 Harward architecture (separate data/instruction) is not used at its best.
It makes load/store unit (LSU) accesses interfere with prefetch unit (PFU) accesses.
So, can we make armcc (with optimization options or some directives...) not generate literal pools ?
Best regards
Christophe
Martin Weidmann
over 12 years ago
Note: This was originally posted on 20th January 2012 at
I'm not sure I agree with your reasoning...
If the section is in cacheable memory, then the fetch would come from the I cache and the load from the D cache. These shouldn't interfere with each other (unless you get to cache misses at once, in which case you'd have contention for the bus interface). If its in BTCM, it can* support two accesses per cycle, so probably no interference there. You would potentially have interference if the section is in ATCM, as that supports only a single access per cycle.
* It's a synthesis choice how to set up the BTCM, no idea how your TI part does it.
That said, I can see why you might want to avoid polluting your D cache with the odd literal stored in memory which is mostly instruction.
Cancel
Vote up
0
Vote down
Cancel
Martin Weidmann
over 12 years ago
Cancel
Vote up
0
Vote down
Cancel
