Site
Search
User
Site
Search
User
Support forums
Arm Development Studio forum
How do I enable 8bit stack alignment?
Jump...
Cancel
Locked
Locked
Replies
Subscribers
118 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Ionut Dinulescu
over 12 years ago
Note: This was originally posted on 20th April 2011 at
http://forums.arm.com
I'm trying to compile a C program with RVDS.
At link time, I get a lot of "myProgram.o(.text) contains invalid call from '~PRES8' function to 'REQ8' function"
I only found an asembly directive (e.g. PRESERVE8) that solves the issue for the .s files but not for c source files.
Is there any linker option that solves this problem?
Ionut Dinulescu
over 12 years ago
--apcs /noswst/interwork/fpic
Cancel
Vote up
0
Vote down
Cancel
Ionut Dinulescu
over 12 years ago
Are you calling any library functions or any function which are written in assembly langauge?
Nope ... all of the functions are written in C.
What I do is compile a library with RVCT 3.1 and compile the application with RVCT 4.0 (some customer request)
If I compile everything with 4.0 or 3.1, everything works fine.
Cancel
Vote up
0
Vote down
Cancel
Ionut Dinulescu
over 12 years ago
The compiler options for both lib and application are: --apcs /noswst/interwork/fpic --littleend -Otime -O3 --forceinline
Cancel
Vote up
0
Vote down
Cancel
Martin Weidmann
over 12 years ago
That is a bit odd, as 8-byte stack alignment should be default setting.
What compiler flags are you specifying? Specifically, are you specifying anything like "--apcs="?
Cancel
Vote up
0
Vote down
Cancel
Junaid Kk
over 12 years ago
Cancel
Vote up
0
Vote down
Cancel
Junaid Kk
over 12 years ago
ok,
Compiler settings for the both are same? Are u using PCS-options ?
Cancel
Vote up
0
Vote down
Cancel
