Site
Search
User
Site
Search
User
Support forums
Arm Development Studio forum
Output data via SWO without debugger ?
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Martin Maurer
over 12 years ago
Note: This was originally posted on 15th November 2010 at
http://forums.arm.com
i am using a Cortex-M3 (in my case a TI Stellaris LM3S9B92 Rev B1).
I would like to know, if it is possible to output data via SWO without a debugger ?
Do i need any clocks (via SWD) from outside (normally generated by the debugger) to output data via SWO (UART, not Manchester) ?
I already tried the following from inside Cortex-M3:
In setup:
#define TRCENA 0x01000000
#define DEMCR (*((volatile unsigned long *)(0xE000EDFC)))
#define TRACE_ENABLE_REGISTER (*((volatile unsigned long *)(0xE0000E00)))
#define TRACE_CONTROL_REGISTER (*((volatile unsigned long *)(0xE0000E80)))
#define ASYNC_CLOCK_PRESCALER_REGISTER (*((volatile unsigned long *)(0xE0040010)))
#define SELECTED_PIN_CONTROL_REGISTER (*((volatile unsigned long *)(0xE00400F0)))
DEMCR = DEMCR | TRCENA;
TRACE_ENABLE_REGISTER = 0xFFFFFFFF;
TRACE_CONTROL_REGISTER = 0x00000001;
ASYNC_CLOCK_PRESCALER_REGISTER = 10;
SELECTED_PIN_CONTROL_REGISTER = 0x00000002;
In main loop:
if (DEMCR & TRCENA)
while (ITM_Port32(0) == 0);
ITM_Port8(0) = 0x41;
But i don't see any activity on SWO, nor is the line switched to output at all...
Best regards,
Martin
Joseph Yiu
over 12 years ago
Note: This was originally posted on 20th December 2010 at
You're welcome.
Cancel
Vote up
0
Vote down
Cancel
Joseph Yiu
over 12 years ago
You're welcome.
Cancel
Vote up
0
Vote down
Cancel
