Site
Search
User
Site
Search
User
Support forums
Arm Development Studio forum
Profiling example code with CortexA9 core option on ARM profiler.
Jump...
Cancel
Locked
Locked
Replies
Subscribers
118 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Sachin Kudva
over 12 years ago
Note: This was originally posted on 29th October 2010 at
http://forums.arm.com
The ARM profiler bundled with RVDS comes with a few examples.
I was able to compile the xvid example with the ARM1136 compiler option (set in make file in ARM folder) and then profile with RTSM_EB_ARM_1136 as target Model as explained in the profiler user guide. I could see the xvid video play and i got the profile figures as well.
Also with the same image i am able to profile by setting RTSM_EB_Cortex_A8 as the target model option. Again, I could see the xvid video play and i got the profile figures as well.
But if i compile the same code with Cortex_A8 as the compiler and the try to profile with the RTSM_EB_Cortex_A8 as the target model, the profiler raises exception.. the code never enters main.. Could some one help me out on this..
I guess it is something to do with initialization of coretx features while compiling. for example the cache related feature etc not taken care in the arm_init.s file in the ARM folder.
Please help.. I am new to all this...
Sachin Kudva
over 12 years ago
Okay if i give the compiler option as
Cortex-A8NoNeon
the code runs. so the issue is with initialization of neon related stuff..
My next question is i have a test code with a couple of neon intrinsic functions. this code is tested on QEMU simulator on cortex-A8 platform by including arm_neon.h.. so if i need to run this on the profiler i need to remove the NoNeon option. so i'm back to the same problem. the code raises exception.
Help!!!
Cancel
Vote up
0
Vote down
Cancel
Sachin Kudva
over 12 years ago
thanks a lot.. looks like there is some extra code for the cpu initialization for 7-A architecture.. but do i need to call this
init_cpu()
function in the main or something.. though it doesn't say so in the code..
Cancel
Vote up
0
Vote down
Cancel
Sachin Kudva
over 12 years ago
sorry for that q.. guess i need to use
--entry=init_cpu
in the make file..
Cancel
Vote up
0
Vote down
Cancel
Sachin Kudva
over 12 years ago
this is great!! thanks scott..
i got my test code running with good results..
now i'm gonna try porting a VP8 decoder code with a lot more neon intrinsics wherever possible....
hoping some good luck!
Cancel
Vote up
0
Vote down
Cancel
Scott Douglass
over 12 years ago
I suspect you may need some code to initialize the coprocessor access register. See [url="
http://infocenter.arm.com/help/topic/com.arm.doc.dui0472b/BGBEJBCF.html?resultof=%22%43%41%52%22%20%22%63%61%72%22%20
http://infocenter.arm.com/help/topic/com.a...b/BGBEJBCF.html[/url]
Cancel
Vote up
0
Vote down
Cancel
