Site
Search
User
Site
Search
User
Support forums
Arm Development Studio forum
Linker Error: Related to ENTRY Point
Jump...
Cancel
Locked
Locked
Replies
Subscribers
118 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Abhinav Varma
over 12 years ago
Note: This was originally posted on 31st August 2010 at
http://forums.arm.com
Hi all,
I am using --entry=startup option with the armlink command.
The command I am using is:-
armlink --cpu=cortex-m3 --entry=startup --scatter=xyz.scat -o abc.exe def.o abc.o --diag_suppress 6238
I get the following error:-
Error: L6204E: Entry point (0x00000290) does not point to an instruction.
In my
assembly code
, I have:-
AREA ||.text.startup||, CODE, READONLY, ALIGN=2
label0
startup
DCD 0x00000000
DCD label1
DCD label2
DCD label2
DCD label2
My
scatter file
has the following contents:-
LOAD_REGION 0x00000000 0x00200000
.text +0
*.text.startup (+RO)
* (+RO)
.data +0
*.data (+RW)
* (+RW)
.bss +0
*.bss (+ZI)
* (+ZI)
I am using
RVDS 4.0
on a
Win XP
with
cygwin environment
Please guide me with this.
Regards
Abhinav Varma
Scott Douglass
over 12 years ago
Usually the entry point of an image points is executable code. Armlink is probably wondering if your image's entry point should be marked as ARM or Thumb. You've already found --diag_suppress; have you tried suppressing L6204 or downgrading it to a warning with --diag_warning?
Also if you're expecting .text.startup to be the first section in the .text execution region, you will need to add +FIRST.
Cancel
Vote up
0
Vote down
Cancel
Scott Douglass
over 12 years ago
Cancel
Vote up
0
Vote down
Cancel
