Site
Search
User
Site
Search
User
Support forums
Arm Development Studio forum
Weak linkage doesn't work as expected
Jump...
Cancel
Locked
Locked
Replies
Subscribers
118 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Richard Gere
over 12 years ago
Note: This was originally posted on 14th May 2010 at
http://forums.arm.com
I am using the weak linkage feature of the Real-View Development suite. It appears that a function that is declared as weak is replaced with a NOP regardless of whether the function actually exists in the image. My original understanding of this feature was that the weakly declared function would not be replaced with a NOP unless it was unresolved at the link stage.
Is there a linker option available to tell the linker to use a weakly defined function which has been compiled and should actually exist in the image?
Thanks in advance.
R.
Scott Douglass
over 12 years ago
Note: This was originally posted on 18th May 2010 at
If you can put all the weakly referenced functions in sections called "keepme" then you could use --keep="*(keepme)". Or you could just use --no_remove if that didn't keep too many things that you did want removed.
Cancel
Vote up
0
Vote down
Cancel
Scott Douglass
over 12 years ago
Cancel
Vote up
0
Vote down
Cancel
