Site
Search
User
Site
Search
User
Support forums
Arm Development Studio forum
Pandaboard - ARM Cortex A9 - cache test
Jump...
Cancel
Locked
Locked
Replies
Subscribers
118 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
vanni genua
over 12 years ago
Note: This was originally posted on 10th January 2013 at
http://forums.arm.com
Hi there, I executed a cache test on Pandaboard (crosscompiled armv7a Linux kernel 3.6.2-rt4), but it seems not to use L1/L2 cache. My test program reads an array of chars many times and varying array dimention. First array dim=512 Second array dim=1024 ... Then doubling upto dim =16777216.
ARM Cortes A9 L1 cache should be 32kHz and L2 cache should be 8MB, therefore I should have slower read time when array dim is 16777216 due to the fact that 16MB is major than 8MB (L2 cache size). Instead nanoseconds per byte time is always the same either for array dim=512 or for aray dim=16777216. So I think cache is not working properly or all data are being fetched from RAM and not from cache. I don't know if this behaviour depends on ARM VIPT d-cache. I attach the cache_test file and its output is shown below. I compiled and executed this way:
#gcc -lrt cache_velocitest_prova-clockgettime_SUPERMOD.c -o cache_velocitest_prova-clockgettime_SUPERMOD.out
#./cache_velocitest_prova-clockgettime_SUPERMOD.out
Array of 512 bytes: 1380700484 nanoseconds
Array of 1024 bytes: 1359279485 nanoseconds
Array of 2048 bytes: 1348870161 nanoseconds
Array of 4096 bytes: 1343367477 nanoseconds
Array of 8192 bytes: 1341046176 nanoseconds
Array of 16384 bytes: 1339836722 nanoseconds
Array of 32768 bytes: 1338830707 nanoseconds
Array of 65536 bytes: 1338569092 nanoseconds
Array of 131072 bytes: 1338442816 nanoseconds
Array of 262144 bytes: 1338121853 nanoseconds
Array of 524288 bytes: 1338144144 nanoseconds
Array of 1048576 bytes: 1338410602 nanoseconds
Array of 2097152 bytes: 1338235811 nanoseconds
Array of 4194304 bytes: 1338208154 nanoseconds
Array of 8388608 bytes: 1338324248 nanoseconds
Array of 16777216 bytes: 1338262426 nanoseconds
Any idea about why nanoseconds per bytes is unchanged even if data are bigger than L2 cache?
vanni genua
over 12 years ago
Note: This was originally posted on 15th January 2013 at
I can confirm timing works right.
Look inside 'lettura' it defines the function which calculate elapsed time.
Long doubles is used to measure timing in seconds.microseconds and it is used to avoid overflow. As a matter of fact Cortex A9 is a 32 bit processor that means overflow if values are over +/-2billions (e.g. 5123456789 nanoseconds would give overflow, therefore a long double lets us express it as 5.123456 seconds).
Look at the attached files for experimental results and the latest source code.
Cancel
Vote up
0
Vote down
Cancel
vanni genua
over 12 years ago
Cancel
Vote up
0
Vote down
Cancel
