Simalar as the issue described here: I can't get a evaluation license.
I cannot get the evaluation license to work. The screen shows
The 'about' box shows
Version: 2024.1-1
Build: 202411903
Please advise. Thanks
Hello Wim,
There is an issue with automatic evaluation license generation (as mentioned in the below thread).
Please download and install the 2024.0 version instead.
I tried to build the Example with ADS 2024.1, but encountered a license issue?
Thank you Ronan,
I have installed
Version: 2024.0-1
Build: 202401904
However, when trying to build the example project "sme_matmul_fp32", I see
although things seem to be configured correctly according to https://developer.arm.com/documentation/ka004977/latest
Please advise. Thanks in advance.Wim
Can you set ARM_PRODUCT_DEF to only point to the 2024.0-1 installation?
Yes indeed. That's it. Thank you.
