Site
Search
User
Site
Search
User
Support forums
Arm Development Studio forum
DS-5 Android - Problem debugging on a device
Jump...
Cancel
Locked
Locked
Replies
Subscribers
118 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
iosif hamlatzis
over 12 years ago
Note: This was originally posted on 19th April 2012 at
http://forums.arm.com
I've finally managed to make the emulator work and now can debug my game on it. Thank you.
As I don't have an actual android device, I've installed an experimental version of ICS on my HP TouchPad. It seams everything works all right. I can use the adb utility provided with the SDK to connect to the device with no problem. But I cannot debug from inside eclipse under windows on the actual device.
I created a second debug configuration for the device and selected my device in the Connection tab at the combo-box, but after a while I receive a message that eclipse cannot connect to the device. This is strange as I have no problem with the connection. Under a dos window using the adb command I can see I can connect, I even can shell into the device.
iosif hamlatzis
over 12 years ago
Note: This was originally posted on 29th April 2012 at
Thank you very much for your support. I've kept the SLEEP variable to 1.5 sec in the python scripts and used the dynamic version of the gdbserver and now all my breakpoints fire.
I need to find my bug now, but when I'll get more time I'll give it a try and get the SLEEP variable back to the default 0 sec.
In the mean time once more, thank you for your help
Cancel
Vote up
0
Vote down
Cancel
iosif hamlatzis
over 12 years ago
Cancel
Vote up
0
Vote down
Cancel
