Site
Search
User
Site
Search
User
Support forums
Arm Development Studio forum
Questions Regarding CMSIS-DAP
Jump...
Cancel
Locked
Locked
Replies
Subscribers
118 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Jesse Ziegler
over 12 years ago
Note: This was originally posted on 25th July 2013 at
http://forums.arm.com
Working on a project to support CMSIS on a third party board with an M4F processor.
Following the CMSIS documentation, it says an HID connection must be established, and then Keil should recognize a CMSIS-DAP connection. My problem is that Windows 7 is showing the HID connection, and the correct string representing the device is showing up in the "Devices and Printers" folder. According to the documentation the HID device just has to be recognized with "CMSIS-DAP" included in the product string, and then Keil should be able to establish a connection. Unfortunately when trying to view a CMSIS-DAP device in Keil, the boxes are grayed out, which I am assuming it means no CMSIS-DAP connection is available and it does not recognize my device. When switching Keil to ICDI connection, it recognizes our device right away (this is the old connection we use, were trying to also implement CMSIS-DAP as an additional USB connection).
Well here are a couple questions:
Since CMSIS uses an HID USB connection, what is the correct way to implement the Report Descriptor? Online examples just handle a mouse or keyboard but I am unsure how to handle an M4F processor that just needs to send packets of data. This is our current Report Descriptor, which returns no errors but may not be implemented correctly:
const
unsigned
char
g_sHIDReportDescriptor[]={
0x06,0xA0,0xFF, //UsagePage (Arbitrary Vendor Defined)
0x09,0x01, //UsageID (Arbitrary Vendor Defined)
0xA1,0x01, //Collection(Application)
//InputReport
0x09,0x03, //UsageID (Arbitrary Vendor Defined)
ReportSize(8),
ReportCount(64),
Input(USB_HID_INPUT_VARIABLE | USB_HID_INPUT_DATA | USB_HID_INPUT_ABS),
//OutputReport
0x09, 0x04,
ReportSize(8),
ReportCount(64),
Output(USB_HID_OUTPUT_VARIABLE | USB_HID_OUTPUT_DATA | USB_HID_OUTPUT_ABS),
0xC0 //endcollection
Does the CMSIS firmware absolutely have to be built in Keil MDK to work or can it be built by third party software? Currently it is being built in third party software and shows up as an HID device on Windows 7, but Keil does not recognize that any CMSIS-DAP device is connected.
If you need any more details in order to answer my questions please let me know.
Thank you.
-Jesse
Reinhard Keil
over 12 years ago
Note: This was originally posted on 26th July 2013 at
CMSIS-DAP is actually implemented with vendor defined HID class (Usage Page ID=0xFF00).
Did you select in MDK uVision "CMSIS-DAP Debugger" under Project - Options - Debug?
Are you using the USB Stack from MDK-Pro or a different implementation?
Maybe it is more effective to communicate with email (
support.intl@keil.com
Reinhard
Cancel
Vote up
0
Vote down
Cancel
Jesse Ziegler
over 12 years ago
Note: This was originally posted on 31st July 2013 at
There has been no response from the support email so I will just post here again.
Reinhard that Usage Page address fixed the USB problem. Now the HID device communicates properly.
The device is recognized by Keil Debugger in CMSIS-DAP mode, but when going to option->debug->settings an error occurs next to TDO. I am attaching an image of this so you know exactly what I am seeing.
It would be very helpful it you could note some problems that may be causing this error.
Thank you
-Jesse
Cancel
Vote up
0
Vote down
Cancel
Bob Boys
over 12 years ago
Hello
Can you try setting the Port: box to SW ?
Bob
Cancel
Vote up
0
Vote down
Cancel
Jesse Ziegler
over 12 years ago
The SW mode returns the same error.
Cancel
Vote up
0
Vote down
Cancel
