Site
Search
User
Site
Search
User
Support forums
Arm Development Studio forum
What is the difference between M4 and MP series
Jump...
Cancel
Locked
Locked
Replies
Subscribers
118 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
O M
over 12 years ago
Note: This was originally posted on 8th July 2013 at
http://forums.arm.com
Hello
[size=2]
[/size]
[size=2]I have to port a project that was written for the ARM11 MPcore to a project that will run on M4 (actually it is freescale Kinetis K60with M4 inside it)[/size]
[size=2]I saw in the documents of the ARM11 MP that it has 2 levelTLB, seven modes of operation (FIQ, IRQ, Supervisor, Abort, System, Undefinedmode), ...[/size]
In the documentation for the M4 I don't find any of it.
May I ask if it is exist in the M4 (K60) and what is themain differences between those two processors ?
Thanks a lot
OM
Peter Harris
over 12 years ago
Note: This was originally posted on 9th July 2013 at
Correct =)
> what is the main differences between those two processors ?
The ARM11 is an ARMv6 processor. It was designed as a applications processor for running full-fat operating systems such as Linux, Windows CE, etc, so comes with an MMU, caches, etc.
The Cortex-M4 is an ARMv7M processor. This has a different processor architecture designed to simplify the core (smaller, more power efficient), and make it easier to program for (fewer operating modes, only implements Thumb/Thumb2 (no "ARM" ISA), you can write most code in C with no need for assembler). As a micro-controller it is designed to be plugged directly to a bus with a local SRAM, so it has no cache or MMU, but can have an optional MPU (memory protection unit).
If you are new to the Cortex-M series I would recommend the "The Definitive Guide to the ARM Cortex-M3" book. It doesn;t cover all of the Cortex-M4 changes, but teaches all of the essentials needed for getting started on the Cortex-M - most of the content is the same for both.
HTH,
Iso
Cancel
Vote up
0
Vote down
Cancel
Peter Harris
over 12 years ago
Correct =)
HTH,
Iso
Cancel
Vote up
0
Vote down
Cancel
