Site
Search
User
Site
Search
User
Support forums
Arm Development Studio forum
Setting an entry point
Jump...
Cancel
Locked
Locked
Replies
Subscribers
118 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Mark Griffiths
over 12 years ago
Note: This was originally posted on 23rd May 2013 at
http://forums.arm.com
Finally I managed to build a static library and I have a xyz.a file and some xyzs.o files. The entry point is xyz_init and I put this as so in the debugger, however on loading I get this:
WARNING(CMD399-COR168):
! Failed to start the target
! No function named "xyz_init" could be found
WARNING(CMD407): Trying the entry point instead
ERROR(CMD426): Cannot find symbol to start or entrypoint, the file or load commands may be used to set the entrypoint
How can I make the debugger see my entry point? Also, how do I load up some symbol files?
Thanks.
Scott Douglass
over 12 years ago
Note: This was originally posted on 24th May 2013 at
There are a few of things that could be preventing the debugger from seeing the xyz_init symbol:
- you might not be loading the image's symbols
[size=2]- the image might not have symbols in it: check the build commands and/or look at the image symbol table by opening it with the ELF Content Editor[/size]
- the linker might have pulled in the code from the library that you think it did: produce a linker map/symbol file and/or use the ELF Content Editor
It's strange that the debugger seems to think that your image has no entry point. What is you link command? What is the earlier output in the Commands view?
You can load symbol files in at least three ways:
- in the debug configuration, Files pane: check Load Symbols on the image you are downloading (if any)
http://infocenter.ar...9980637970.html
- in the same pane lower down: add a Load Symbols from File entry
- in the Commands view (or Debugger pane of the debug config): manually use an add-symbol-file (etc.) command
Cancel
Vote up
0
Vote down
Cancel
Scott Douglass
over 12 years ago
Cancel
Vote up
0
Vote down
Cancel
