Site
Search
User
Site
Search
User
Support forums
Arm Development Studio forum
armcc
Jump...
Cancel
Locked
Locked
Replies
Subscribers
118 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
armcc
Simha JKC
over 12 years ago
Note: This was originally posted on 5th April 2013 at
http://forums.arm.com
Is there a compiler option or pragma that allows me to see "padding" in c structure?
typedef struct st
char a;
int b;
} mytype; Basically, say I have above defined struct then I wish to known how compiler pads it.
list file does not seem to provide the needed details.
--diag_warning=1301
--diag_warning=2530
I tried above options, it shows warning when ever the compiler pads but the issue is i still do
not get how many bytes and where the padding is applied in the structure.
is there a easy way to get those two details ?
Simha JKC
over 12 years ago
Note: This was originally posted on 9th April 2013 at
thanks for sharing additional information.
@scott
: your suggested idea is not feasible as i am dealing with structures that are huge i.e., size is in 100s of KBs with many types of data types [size="2"]used in struct
[/size]
@archie:
i tried using "--remarks" it still does not help as it does not provide padding size and also the place where it is padding. below is the compile log
C:\c>armcc --remarks 1.c
"1.c", line 3: #1301-D: padding inserted in struct st
"1.c", line 3: #2530-D: padding added to end of struct st
"1.c", line 14: #181-D: argument is incompatible with corresponding format string conversion
printf ("sizeof (me) = %d \n",sizeof(me));
"1.c", line 16: Warning: #1-D: last line of file ends without a newline
1.c: 1 warning, 0 errors
C:\c>
recently i tried "fromelf" with option "--expandarrays" and even that is not helping me.
Cancel
Vote up
0
Vote down
Cancel
Scott Douglass
over 12 years ago
Note: This was originally posted on 8th April 2013 at
I don't think there is a way to get the compiler to be more specific about the padding. The structure layout rules are in section 4 of the ABI
http://infocenter.ar...042e/index.html
. You could manually add 'char dummy1;' members until the padding warnings go away and then you'll know that you've identified all of the padding.
Cancel
Vote up
0
Vote down
Cancel
