Site
Search
User
Site
Search
User
Support forums
Arm Development Studio forum
ARMCC compiling for A7
Jump...
Cancel
Locked
Locked
Replies
Subscribers
118 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Mohit Taneja
over 12 years ago
Note: This was originally posted on 28th March 2013 at
http://forums.arm.com
I am trying to build my project for the cortex A7. I am currently running an older version of the realview tools. I wanted to know what the difference is between the cpu = 7-a and cpu = cortex-a7 options was?
Will the A7 be able to run code compiled using the 7-a option?
Mohit
Mohit Taneja
over 12 years ago
Thanks!
I take it I wont have access to LPAE either?
Cancel
Vote up
0
Vote down
Cancel
Martin Weidmann
over 12 years ago
The Cortex-A7 processor implements ARMv7-A. So compiling generically for ARMv7-A will produce compatible code. What the compiler will not do is optimize the code specifically for the Cortex-A7's pipeline.
The other potential issue is extensions. ARMv7-A has a number of optional extensions. The Cortex-A7 implements a couple of them, for example Virtualization. If you build for the base architecture, the tools will fault if you try to use an instruction that was added by an extension. That said, I don't usually find this to be a problem if I'm compiling C code. It tends to only be assembler (e.g. hand written init code) that uses this kind of feature.
Cancel
Vote up
0
Vote down
Cancel
Peter Harris
over 12 years ago
IIRC LPAE isn't an ISA level extension, so I don't think the compiler output changes.
Cancel
Vote up
0
Vote down
Cancel
