Site
Search
User
Site
Search
User
Support forums
Arm Development Studio forum
NEON vdiv.f32 syntax
Jump...
Cancel
Locked
Locked
Replies
Subscribers
118 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Carl van Heezik
over 12 years ago
Note: This was originally posted on 17th April 2012 at
http://forums.arm.com
I am (re)coding a 3D math library with inline NEON assembly for iOS using the Apple LLVM compiler 3.1.
I get an error message on the following instruction:
[color="#000000"] "vdiv.f32 q0, q1, q2 \n\t" [/color]
VFP single or double precision register expected -- `vdiv.f32 q0,q1,q2'
According to the 'Assembler Reference' page 4-76 you should specify a single precision register. The following code works:
[color="#000000"] "vdiv.f32 s0, s4, s8 \n\t" [/color]
"vdiv.f32 s1, s5, s9 \n\t"
"vdiv.f32 s2, s6, s10 \n\t"
I am confused because now the divide is not computed in parallel, which was the reason to use inline assembly.
Also the following instructions work as expected:
[color="#000000"] // component wise add[/color]
[color="#000000"] "vadd.f32 q0, q1, q2 \n\t" [/color]
[color="#008311"] // component wise subtract
[color="#000000"] "vsub.f32 q0, q1, q2 \n\t" [/color]
[color="#008311"] // component wise multiply
[color="#000000"] "vmul.f32 q0, q1, q2 \n\t" [/color][/color][/color]
[color="#000000"]
[color="#ce2f24"][color="#000000"]Why do I get an error message on the vdiv and not on the vadd, vsub and vmul? Is this a compiler error?[/color]
[/color][/color]
Etienne SOBOLE
over 12 years ago
I see the problem
Use this PDF documentation instead
http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.ddi0406c/index.html
chapter A8.8.312
It's said "Encoding T1/A1 VFPv2, VFPv3, VFPv4"
VDIV is not a NEON instruction.
Vpf and NEON are not the same computing unit.
ARM have decided to unify the instruction syntax but the two unit are very different !!!
Etienne
Cancel
Vote up
0
Vote down
Cancel
Etienne SOBOLE
over 12 years ago
I see the problem
chapter A8.8.312
Etienne
Cancel
Vote up
0
Vote down
Cancel
