CORTEX R5 TCM ECC ERROR ISR NOT working
We are trying test TCM ECC Error ISR, on Cortex R5. But we are failing to get ISR for this fault.
So, can you please clarify on this, whether we have any known issue with this ?? or any fix we have to get this ISR reported.
We are using this below sequence
void corrupt_a_tcm() {
  //; Setup - these addresses MUST be doubleword aligned
       asm("LDR r10,=0x0000F100");     //; Address of victim TCM location to insert error
       asm("LDR r6,=0x0000F108");      //; Address of scratch memory location (r6, NOT r11/fp - see above)
       asm("LDR r0,=0xDEAFBEEF");
       asm("LDR r1,=0xCAFEBABE");
       asm("STR r0,[r10]");
       asm("STR r1,[r10,#0x4]");
  //; Disable ECC - ATCM
       asm("MRC p15,0,r0,c1,c0,1"); //; Read aux ctl
       asm("BIC r0,r0,#0x02000000");
       asm("MCR p15,0,r0,c1,c0,1");
  //; Memory barrier to ensure SQ is empty - otherwise data may come from other ; sources and not get corrupted in the way we want
    asm("DMB");
  //; Read data and introduce ECC error
       asm("LDRD r0,[r10]");         //; Read data to corrupt
       asm("STRD r0,[r6]");          //; Store data to corrupt in scratch location
       asm("LSR  r2, r0, #16");      //; Only interested in 3rd byte
       asm("EOR  r2, #0x2");         //; Toggle one bit
       asm("STRB r2,[r6,#2]");       //; Store byte to corrupt data and ECC
       asm("LDRD r0,[r6]");          //; Load corrupted data back to set up internal registers
       asm("BFI  r0, r1, #0, #8");   //; Merge byte 0 from upper word into lower word
       asm("ROR  r0, r0, #24");      //; Shift byte 3 into byte 0 position, byte 0 into byte 1 position.
       asm("STRH r0, [r10,#3]");     //; Store byte - data unchanged, but ECC changed
    //; Enable ECC
       asm("ORR r0,r0,#0x02000000");
  //; Read data - should get corrected from 0xDEAFBEEF to 0xDEADBEEF
