Clock Gating Cell Missing Module
I'm currently developing a Cortex-M0 SoC and using the CMSDK one of the module (cm0_pmu_acg_tsmc180.v) need another module called "TLATNTSCA_X8_A7TULL" but when I have downloaded using the IP it doesn't have any module with that name. Are there any solution for the problem I'm facing?
  • The module cm0_pmu_acg_tsmc180.v references a technology-specific standard cell named:
    TLATNTSCA_X8_A7TULL
    This cell is not included in the CMSDK package or any publicly available IP from Arm. Instead, it is a process-dependent library cell, most likely from TSMC’s 180nm A7TULL standard cell library. As this is a foundry-specific component, it is not modeled behaviorally in Verilog and thus does not appear in the CMSDK download.
    If your objective is simulation only and not gate-level synthesis or physical implementation, you can use the generic model provided at:
    <your_cortex_m0_dir>/logical/models/cells/cm0_pmu_acg.v
    Important: For synthesis or formal verification, you must replace the simulation model with a technology-specific architectural clock gating cell from your chosen standard cell library. This ensures correct glitch-free behavior on the gated clock output and aligns with physical implementation requirements.
  • So if i want to run the RTL synthesis and physical implementation i should get the TSMC 180nm A7TULL IP or use another PDK module?
  • Yes, for RTL synthesis and physical implementation you need both the TSMC 180 nm A7TULL standard-cell library (with the ICG cell). Otherwise, use your own PDK + its ICG cell and remap the module.
