Hi all,
I need to enable exception handling in case of dividing by zero in case of float numbers yet I am not sure even if it is supported in cortex R7 could someone help me if i am missing something .
Thanks .
In Cortex-R7 Technical Reference Manual (TRM), you can find SCTLR.DZ bit ( SCTLR.bit[19] )
Divide by Zero fault enable bit. This bit controls whether an integer divide by zero causes an UNDEFINED Instruction exception:
