armv8 write-back cache
hi there, i'm using A53 without OS, and configure memory attribute as write-back.
when i write a dword num to memory addr, i found that external reader could not read it as expect. then i change memory to non-cache, it works ok.
so, when write-back cache, how could i trig ddr update when i write a dword num?
