why PSTRB signal in APB4 have four bits?
PSTRB signal indicates which byte lanes to update during a write transfer.
it shows that the bus contain valid data, when PSTRB[3:0]=1111.
why we need bus instead of single bit PSTRB signal?
  • Hello,
    This might be of help.
    -amol
  • In the APB spec in table 2.1 there is a description of each signal, and the description for PSTRB indicates...
    "There is one write strobe for each eight bits of the write data bus.
    Therefore, PSTRB[n] corresponds to PWDATA[(8n + 7):(8n)]."
    See also section 3.2 which describes the write strobes.
    The APB write data bus PWDATA has a maximum (and typical) width of 32-bits, so 4 write strobe bits are required for that scenario.
    If you have a system with a 16-bit or 8-bit PWDATA bus width, the width of PSTRB implemented would be narrower.
