I know how to debug mcuboot and tfm-s image, it can be done in this way:
Start the CADI Debug Server in one terminal:
/usr/local/DS-5_v5.27.1/bin/FVP_MPS2_AEMv8M --parameter fvp_mps2.platform_type=2 --parameter cpu0.baseline=0 --parameter cpu0.INITVTOR_S=0x10000000 --parameter cpu0.semihosting-enable=0 --parameter fvp_mps2.DISABLE_GATING=0 --parameter fvp_mps2.telnetterminal0.start_telnet=1 --parameter fvp_mps2.telnetterminal1.start_telnet=0 --parameter fvp_mps2.telnetterminal2.start_telnet=0 --parameter fvp_mps2.telnetterminal0.quiet=0 --parameter fvp_mps2.telnetterminal1.quiet=1 --parameter fvp_mps2.telnetterminal2.quiet=1 --application cpu0=~/TF-M/trusted-firmware-m/cmake_build/bl2/ext/mcuboot/mcuboot.axf --data cpu0=~/TF-M/trusted-firmware-m/cmake_build/tfm_sign.bin@0x10080000 -S
Start debugger in the other terminal to debug secure image:
/usr/local/DS-5_v5.27.1/bin/debugger --cdb-entry "ARM FVP::MPS2_AEMv8M::Bare Metal Debug::Bare Metal Debug::Debug AEMv8M_0" --image "trusted-firmware-m/cmake_build/app/secure_fw/tfm_s.axf"Connected to stopped target ARM_AEMv8M_0Semihosting server socket created at port 8000Semihosting enabled automatically due to semihosting symbol detected in image 'tfm_s.axf'>b mainBreakpoint 1 at 0x10085CD0 on file tfm_core.c, line 159>cExecution stopped in Secure Thread mode at breakpoint 1: 0x10085CD0In tfm_core.c0x10085CD0 159,0 {>sExecution stopped in Secure Thread mode at 0x10085CD80x10085CD8 160,5 uart_init(UART0_CHANNEL);
But if I try to debug the non-secure image:
/usr/local/DS-5_v5.27.1/bin/debugger --cdb-entry "ARM FVP::MPS2_AEMv8M::Bare Metal Debug::Bare Metal Debug::Debug AEMv8M_0" --image "trusted-firmware-m/cmake_build/app/tfm_ns.axf"Connected to stopped target ARM_AEMv8M_0Semihosting server socket created at port 8000Semihosting enabled automatically due to semihosting symbol detected in image 'tfm_ns.axf'>b mainBreakpoint 1 at 0x00102358 on file main_ns.c, line 100>c>sERROR(CMD440-COR89): ! Stepping failed! Target is currently running
The execution simply cannot achieve achieve the main() of non-secure image. And I know the root cause of the problem is the execution entry point and secure non-secure switch. But I just don't know how to make it right. Any idea? Thanks.
To debug non-secure image, I have to do it this way.
In another terminal:/usr/local/DS-5_v5.27.1/bin/debugger --cdb-entry "ARM FVP::MPS2_AEMv8M::Bare Metal Debug::Bare Metal Debug::Debug AEMv8M_0" --image "trusted-firmware-m/cmake_build/app/secure_fw/tfm_s.axf">add-symbol-file trusted-firmware-m/cmake_build/app/tfm_ns.axf>b trusted-firmware-m/cmake_build/app/tfm_ns.axf:main
Then, everything works as expected.
