Cortex-A5 and configuration for real time task
in my recent design I have used a processor with Cortex-A5 core (it is SAMA5D27 from Microchip). There is one critical task which needs to be performed in real-time. Could you, please, give me a hint on how to configure the processor for that?
My system runs with a bare-metal application (custom firmware), not any "big" OS.
The critical task involves iterating in a loop, each iteration should last no more than 1us. I believe this is possible, but my best time so far is almost 8us. I can see that the reason is very slow access to peripherals on APB. According to specification of the processor I've expected five-six cycles of system clock, that would be fine. But the accesses can take ten-twenty times more.
During execution of the critical task the processor doesn't have to deal with anything else. Just this thing, everything else can wait. The execution of the critical task starts on user command, and it can take whatever time necessary to prepare for execution.
I think that the reason of the problem is that the system tries to be too versatile. During execution of the task I need only access to peripherals on APB (GPIO controller and four SPI controllers), and to DDR memory. (And probably to SRAM, where is the code of the application - but maybe it is I-cached already?) There is no need to access anything in parallel with something else.
Each iteration reads one 32-bit value from DDR. Then it only acceses GPIOs and SPIs. After it finishes all the transfers, it stores four 32-bit values in DDR.
First I've run the firmware with only I-cache enabled. With enabled also MMU and D-cache it seems to run a bit faster. The system also has L2 cache, which is enabled.
I am a hardware designer and so far I have no programming experience with caches and MMU. Do I need those things here? Is it possible that they are somehow "misconfigured" from my point of view and impede the operation? Which features would make such task run faster? Is it possible to configure AHB and APB so that such accesses which I need could be really quick?
Please, any hints will be appreciated.
Best regards,
Adam
