A panic function to halt the processor in low-power sleep using WFI?
As part of fault detection / debugging, it's useful to have a panic() function that halts the processor.
It is easy enough to disable interrupts and put the processor in an infinite busy loop (while (1)). However, that burns power, and I am looking for an alternative that keeps the processor in a low power state (until NMI or hard reset). Is there a way to implement such a halting fuction?
On an emulated M4 (Qemu), I tried disabling interrupts and WFI:
panic() { CPSID I; while(1) { WFI } }
*EDIT: my original post had a typo: CPSIE instead of CPSID
But this won't work of course, because WFI has to ignore the interrupt priority to be at all useful, so once an interrupt of any priority happens to occur, the WFI returns. The ISR is not invoked of course, so the interrupt remains pending. WFI is re-entered immediately but also returns immediately (since that interrupt is still pending). So, the panic again becomes a busy loop that goes in and out of WFI on every cycle, so it burns as much power as a while(1) busy loop.
I don't think even clearing all pending interrupts in the NVIC will help, because the signal from the device that outputs the interrupt will remain asserted, so a level-triggered interrupt will just immediately re-pend itself again. Correct? And, clearing the interrupt in the device is not an option, because the whole point is to not run any code after panic(), so certainly do not want to execute the ISR.
I haven't tried on real hardware yet, but I expect the real hardware has the same behavior as this emulator (because this is the expected behavior by spec, right?).
